OBDII port not working, brake and gas light on. Need help.
I have been trying everything in my power to figure out why my OBD port is not working. Has the bright light on the gas and the speedometer not working. I try my best to look for any grounds in the dashboard wire hornist I don’t have a wire hornist I don’t have any fuses blowing on the hood name on the steering wheel? I don’t know what else to do so anybody help me or leave me in the right direction thanks!!
You post this at 5:23am on a Sunday morning and you expect help right away? oof
Your description is poor. What is the main issue? Brake light is on? How does the car drive and behave?
Check out this thread. There are two good suggestions within that worked for other Maxima owners. Let us know if you fixed the problem.
https://maxima.org/forums/7th-genera...obd2-port.html
So now is the time to brimg out a voltmeter or test light. Test pin 16 to a good ground. If power there, then check between pins 16 and pin 4. Most likely this will show 0 volts. If no power to pin 16, you have a wiring or connector issue. You are just going to have to use your tools and Mark 1 calibrated eyeball to track it down
I’ll say like a month ago I had it hooked up and it cleared a i’ll see you like a month ago I had it hooked up and it cleared code and then next to you know stop working
chris.tremblay
Mar 21, 2004 02:40 PM
vinnieloo
Nov 14, 2002 08:04 PM
