Need To Know What To Do.....Install My H&R Springs on stock struts or buy The AGX???
I have 15k miles on my car...should I install the H&R springs on w/ my stock struts still struts wear out? Or should I buy the modified AGX Struts that cattman sells? Need your input....Also what so good about the AGX that I hear alot & whats it good for?
Thanks ahead for the help!
Originally posted by dmbmaxima88
the agx's are plug and play, very very good, easy to adjust while they are on the car, and last for a long time. don't lower the car without them..
Originally posted by K Pazzo 6
I'm not too familar w/ all this....but you say 'easy to adjust'...whats the point or reason for adjusting?
I am planning to do the same thing, install H&Rs on my car, but I am going to use stock shocks.
I used to have H&Rs on my 95 Maxima with Tokicos and Tokicos sucked so bad. So I don't know about other after market shocks.
I don't know much about AGX, but I definetly don't need that adjusting stuff.
There are people here on the .org that have lowered their car with H&Rs and used their stock shocks, and they say car rides fine on stock shocks. No problems.
please don't lower your cars on stock shocks, it's jjust not right, mine on my 95 blew after about 100 miles, i drove to maxus (400miles each way) with a dead rear and a dying rear shock, not fun. i got toks after that, they were better but not the greatest, they work, but this time it's AGX's baby. it's not worth the efffort to reinstall stuff a second tiem when you have to replace teh springs.
Originally posted by Greek to the Max
See, you talk about wasting money, AGX's are a laugh to. Listen, find me a 5th gen Se driver who's shocks blew out that fast.
So are you saying that the 5th Gen shocks are higher quality than previous generations? Just curious, I also want to put on a set of H&R springs on my '02 SE but don't really want/need the adjustibility of the AGX's. I just want to get the car down a couple of inches.
Originally posted by acMAX
...I've heard that your stock struts will wear down faster with the aftermarket springs..
Isn't there a bump stop/cushion on the stock strut/spring setup designed to prevent the strut from being compressed past its design limits?
Is this bump stop/cushion modified in any way when shorter springs are installed?
On the KYB AGX's are the front and the back both plug and play, cause i'm pressed for money so the install would be done myself with friends. I've already done the fronts and i plan to do the rear with progress springs and i'm going to just wait for the new struts does anyone have any tips for me on the rears it looks a lot more complex than the fronts
Originally posted by PapaTango
Greek,
Greek,
2 inches eh, well you are asking for alot. All I have learned from my searches is that SE Shock & Struts and stronger and spotier then the other models, thus explaining why they last longer with aftermarket springs. Mind you, going higher then 2 inches is asking for alot from any stock unit.
The Frye
Sep 2, 2021 11:03 AM
Justin Kroll
Sep 2, 2015 11:06 AM
