so. what's the answer to water in the clear side markers?
Ive used SEARCH to find threads on this but no luck.
Has anyone got an answer to get the moisture out of the clear side markers? NO I DONT WANT TO BUY A NEW PAIR.
Roger
Roger
Hello.Ive read something about sealing the new markers with silicon.I belive the instruction are at 5thgenmaxima.com or custommaxima.com.If I can find them I will send it to you.I just ordered my clear markers 5 minutes ago and I do not want to have that probem also.By the way,how do they look.Ive got a 2k2 sterling mist and they should look pretty sharp.Also did you put red bulbs in the rear and if so where did you get them.Thanks and good luck.
yeah def silicone
polarg 194 wedge red bulbs i believe9. 10 bucks for 2 bulbs. I bought them from a local rice shop. I was contemplating getting superwhite wedge bulbs, but then again... no
Roger
When I first installed my clears I didn't bother putting on silicone to seal out the moisture. Because of this there was a sh*itload of moisture in them. They recently got stolen off my ride so I bought new ones. This time I took the time to properly seal them with some clear silicone. Even since then not one drop of moisture. I would definitely recommend taking the time to carefully seal them properly.. They look better with no moisture in them
Before you seal them up, stick them on a cookie sheet in the oven with some dessicant at a low setting...around 110 or so. This should dry out the moisture. Then cool them down and seal them up with silicone.
Re: so. what's the answer to water in the clear side markers?
Here are the instructions:
http://www.5thgenmaximas.com/clearinst.html
Definitely a good idea to seal them. I sealed mine..
Re: Re: so. what's the answer to water in the clear side markers?
Hey roger..
Once you get water in them.. They never come out.. I've tried everything from the blowdryers to cooking them in the oven... When it finally seemed like the water had disappeared, it would comeback after a trip to the car wash...
I'm just going to go and buy me a new set since it's only about $50..
If you want.. You can steal toylet's..
SHHHHHHHHHHHH.... LoL!!!!
I'm just going to go and buy me a new set since it's only about $50.. If you want.. You can steal toylet's..
Re: yeah def silicone
Originally posted by radpp16
I got the bulbs from
Roger
Roger
a reason to pull me over.
Re: Re: Re: so. what's the answer to water in the clear side markers?
Originally posted by RBa
Hey roger..
Hey roger..
I have no more problems...except the dam pink lights!! I need to find a good RED bulb.
Brian
boomerbrian
Oct 31, 2018 10:25 AM
Maxima30
Sep 7, 2015 06:13 PM
