HELP! AutoLoc one touch/sunroof not working...
I've connected all the wires according to ericdwong's writeup....and the map light works, but the sunroof retract/close & up/down switches are dead. I did this job with the sunroof open (dumb) so now the damn thing won't close. Can anyone who's done this job suggest what could be wrong? I've read over the instructions time and time again, but everything looks okay. ****......
Originally posted by ericdwong
Lets see...did you connect the "constant hot" BEFORE the maplight? Cause if you connect it after, there will be no power. Do you have a multimeter?
No, I don't have a multimeter.
Originally posted by thebigsadler
take it all apart.. wire it back up to factory.
close the sunroof.
rewire and try it
close the sunroof.
rewire and try it
When I wire everything up and turn the battery on the two sunroof switches are dead. Then I disconnect the WC1000 green wire from the switch green, the window retracts. When I reconnect the green wire, the retraction stops. When I disconnect the WC1000 blue wire, the sunroof closes. When I reconnect the wire, the closure stops. It seems like I have power, but I don't know what wire could be connected wrong. Could my factory alarm play a part in this? I'll call AutoLoc tomorrow and see if they can help me.
good idea with calling autoloc, as far as the factory alarm i dont know..
i am having trouble getting mine done with my viper 800 esp.. i have come to the conclusion that i dont need tilt so i will just use one switch and erase the tilt function from my sunroof which doesnt bother me at all.. but it is not looking good as of yet.. have to wait and see i guess.
the wire harnesses for mine are all off the alarm which is under the dash.. so thats where the box goes, and the wires get run up through the headboard with a wire snake to the sunroof controls.
thisasian
Aug 7, 2002 04:21 AM
97BLKMAXSE
Jul 11, 2002 05:23 AM
ptatohed
Feb 15, 2002 10:00 AM
