Brakes? I don't need no stinkin' brakes! (HELP!)
Thought the brakes were getting a little weak the past couple of weeks. Sucks since I just bought the car from the dealership.
- Having to crush the brakes to the floor to get it to stop.
- Slight squeal from the brakes when pressed down.
- Pressure is there, seem to be getting fluid pressure (if that makes sense) but the metal to metal just doesn't seem to be happening.
Going to inspect the brakes and take a couple of pics if I can, maybe that'll help.
Thoughts?
Thoughts?
Re: Brakes? I don't need no stinkin' brakes! (HELP!)
Thoughts?
Thoughts?
It would help if you describe your car... I'm assuming it's new.
1. Check your front and rear brake pads, they have wear indicators.
2. I would bleed the system, maybe you have an air bubble in the lines?
3. Add Blue goo, this will help stop the squeaking.
Good luck.
PS - One note, front calipers compress, rear calipers can't be compressed they need to be rotated in (I learned this the hard way). This is on a 4th gen, not sure about other gens.
Good luck.
Thoughts?
Thoughts?
Vinipux
JoshG
Sep 5, 2015 10:10 PM
