Will this wheel + tyre combo fit???
Hey, just need some info on this wheel + tire combo i want to put on my 93 maxima. I want to go 17" rims with 225/45/17. I also want to lower the car too. I want to know will this rub on my guards. Any info on this would greatly appreciated!!!!
Cheers EdzMax
Cheers EdzMax
Re: Will this wheel + tyre combo fit???
Cheers EdzMax
Cheers EdzMax
Re: Re: Will this wheel + tyre combo fit???
Originally posted by crazy4maxima
http://www.iridiumpower.com/default.asp?flash=1 here just plug in your stock tire size then input the size you want to go... the calculator will show the speedo difference in the size of tire... so far.. it shouldnt be a big issue... with these size tire rim combo, when you travel 60 the spedo will read 58.8mph.. so your speedo will be slow.. not too big of a deal.. just becareful not too speed...;-p just take a look and click
Re: Re: Re: Will this wheel + tyre combo fit???
Thanks for the info, i will remember that. But what i really wanted to know if I did get these wheels, will i rub on the guard? Thats my biggest worry, spending hundreds on tires & then have them wear out on me. Can't afford to spend money on tires. So need to know if anybody has had problems with these tires on thier maxis. Cheers for that, though!!!!
good luck
oops so sorry this is the link
http://www.miata.net/garage/tirecalc.html
i had copied the worn link , this is the correct one.. sorry about the confusion
Re: Re: Re: Re: Will this wheel + tyre combo fit???
Originally posted by awsm66
That size tire if fine IF you get the correct backspacing on the wheels. I have the same tire size and have no rubbing what so ever. It all depends on backsapcing and before you ask no I dont know my backsapcing sorry I didnt ask when I got them.
good luck
good luck
Re: Re: Re: Re: Re: Will this wheel + tyre combo fit???
Thanks awsm66, thats what i wanted to hear. My friend at work wanted to know what is backspacing?? I like ths lights, how much were they?
check out www.tirerack.com for some basic info about it (I found info about it on there somewhere before)
Re: Re: Re: Re: Re: Re: Will this wheel + tyre combo fit???
Originally posted by «§»Craig B«§»
backspacing is alos known as offset
EdzMax--All of the wheels for front wheel drive cars are measured in offset I think. There is a difference in offset and backspacing. I remember reading about it on here so you should find it if you search for "offset".
Violator
Sep 9, 2015 10:14 AM
carid
Sep 9, 2015 05:06 AM
