Dual Guage Pod,Which Guages are the "easiest" to install?
I want to order the Auto Meter Dual Guage pod from http://www.CustomMaxima.com and I want to put Voltmeter and fuel/air gauges in are they hard to do or which gauges are easiest to do I don't have boost or nitrous or anything. And where is the best place to get the gages from I want the ones with white faces
The volt meter and the clock are probably the easiest to install.
A/F ratio is not that hard either. Tranny temp is not hard either. Harder ones are like oil pressure, oil temp and EGT . Intake temp is easy to install but that gauge/sender is expensive.
RWCreative
09-21-2015 11:01 AM
Justin Kroll
09-02-2015 11:06 AM
