Remote Bottle Opener question
Old Nov 24, 2002 | 06:02 PM
Battle Max
sup all i just picked up a zex remote bottle opener and i was curious for those that have bottle openers where did you mount the switch????? also the zex kit uses a flat black switch that clicks up and down but they guy thats helping me install it uses a toggle switch without the plastic cover....i like the switch that zex includes but the only problem is its in a rectangle shape so it looks like a dremel would be needed to make it lay flush..
thanks
Jon
Old Nov 25, 2002 | 07:23 AM
JAIMECBR900's Avatar
I have mine mounted where the change holder is on the center console (between the e-brake and the flip up armrest). I only used a toggle switch, so it's easier to mount. I know which switch "pod" you are talking about. If you want to use that one, you're going to have to get a little more creative because it requires a lot more room to mount.
pears
Sep 18, 2015 05:25 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
