Fuel Pressure Gauge:Electrical or Mech?
What kind of Fuel Pressure gauges does everyone have? I am looking for an electrical one but do they even have them? I also found an electric oil pressure gauge. Can I use it for the fuel instead since it only measures pressure?
Re: Fuel Pressure Gauge:Electrical or Mech?
For awhile, I thought mechanical gauge could be used inside the cabin with an isolator. I was dead wrong. It would only work if the car runs on carburator with less than 15psi of fuel pressure. With fuel injected car, the fuel pressure gets way too high even for an isolator. With Maxima, eletrical fuel pressure gauge is the only option.
Originally posted by Jime
If you are going to use it in the cabin it has to be electrical or mechanical with a remote sender.
Autometer has several eletrci fuel pressure gauge models.
Sport-Comp
Phantom
Ultra lite
Carbon fiber
Pro-comp
http://www.autometer.com/hp/2001_cat...tition/46.html
http://www.autometer.com/hp/2001_catalog/racing/60.html
http://www.autometer.com/hp/2001_catalog/racing/64.html
http://www.autometer.com/hp/2001_cat...tition/51.html
Sport-Comp
Phantom
Ultra lite
Carbon fiber
Pro-comp
Re: Re: Fuel Pressure Gauge:Electrical or Mech?
Originally posted by ToYLeT902
i have the autometer phantom series electrical fuel pressure gauge (full sweep)... they cost a lot, around 200
LoL.. Let's have an install meet tomm in your garage..
You can practice on mine so you'll have experience when your gauge comes in the mail..
BTW.. I have the Sport-comp series full sweep electrical FP... I got mine for free with my SC....
I never seen an autometer mechanical fuel preesure gauge with a remote sender. By remote sender, do you mean the isolator? Eletrical fuel pressure gauge does come with an eletrical sender. It's a round cylinder thing that has wires coming out.
Autometer sells a 0-100 psi with a remote sender. You just have to go to the correct vendor.
Hmmm what about:
Autometer part: 5282
http://www.autometer.com/hp/2001_cat...sories/90.html
Summit sells it here:
http://store.summitracing.com/partdetail.asp?part=23219
Originally posted by Maksim2000
Hmmm what about:
Hmmm what about:
Regardless I still think the electrical gauge is the way to go.
In the end if you wan't to go mechanical you pay:
$95 isolator
$40 gauge
$10 in random fittings
$145
+ the hassle of running liquid filled line to the gauge
for the electrical you'll pay:
$190 Gauge+sender
$5 of fittings.
$195
But is is "plug and play".
or you can just get an "under the hood" gauge for a bout $40
so if you want the gauge inside expect to at least pay $100 over the regular under the hood gauge.
The autometer sender is different between the fuel pressure gauge and oil pressure gauge. Oil tends to be thicker than gasoline. It will work probably but how well and how long is unknown.
What about my idea of using an oil gauge as a fuel pressure gauge? Will it work since it measures pressure? Or does the difference between oil and fuel mess the readings up.
The autometer sender is different between the fuel pressure gauge and oil pressure gauge. Oil tends to be thicker than gasoline. It will work probably but how will and how long is unknown.
2242 (oil pressure sender) is $25 and 2248 (Gasoline sender) is $27
Which makes me wonder why there is such a price difference between gauges ...
Keep in mind Autometer had a recall on the short sweep eletrical fuel pressure gauge so you can't get sender 2248 anymore. The full sweep sender is totally incompatible with short sweep gauge. The short sweep fuel pressure guage is much cheaper.
The price diffrence between the two senders is very small
I doubt it.
I mean for electrical gauges. I have an oil pressure gauge and I have seen that the price for it is $99 instead of $200. Can I use this gauge instead and buy the gasoline sender?
http://www.egauges.com/vdo_send.asp?Sender=100PSI_US
Do you know what the part number is for the new sender is ? 'Cos autometer catalog doesn't list anything else like that.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
