first 2002 with NX setup up and running ! =]
Old Feb 19, 2003 | 12:46 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Hey guys! just wanted to let everyone know im the first!
With the NX that is..unless someones hiding
Only on a 35 shot right now.
I raced a Mustang Saleen 281 while I was tested the baby out.
I smoked that sucker from the line 2-3 cars.
From a rolling was a different story We were even. Dead even.
Not bad for a car that runs 0-60 in 4.8 and me with a 35 shot in an untuned system. Not even running bottle pressure. Bottle was pretty cold. WOuldnt doubt if it was at ~600 psi
I Cant wait for the 75 shot!
Old Feb 19, 2003 | 04:22 AM
Jime's Avatar
I don't wanna hear about it, thats what I wanted to do this year.
You should be able to run a real low 13 with the 75, if you have slicks. I ran one 13.8 with the 50.
Old Feb 19, 2003 | 04:26 AM
XXXL Cracker's Avatar
Congrats on the install. With a 75 shot you should smoke some fools
Dave
Old Feb 19, 2003 | 09:30 AM
WizzaMax's Avatar
glad it worked out...did you get the AF ratio gauge in ok?
enjoy safely and make certain you keep tabs on teh weight of the bottle...anything at 17# or below will not give you good results
Old Feb 19, 2003 | 09:46 AM
Eat Naaawwwzzzzz
actually i havent got around to the gauge yet, im not using the system anymore until im done. I had a dilemma with the wiring of the O2 sensors, maybe u can help me
http://forums.maxima.org/showthread....hreadid=190637
Ill be going to the fontana track march 9th =]
i wonder what i run
thanks!
Old Feb 19, 2003 | 01:49 PM
WizzaMax's Avatar
http://forums.maxima.org/showthread....01#post1785001
maybe this helps...
Old Feb 19, 2003 | 02:16 PM
Supermax95's Avatar
Get the 75 shot in....then well talk!!
congrats tembelino!
Old Feb 20, 2003 | 10:00 PM
Eat Naaawwwzzzzz
im gonna try the right wire, it should be 1-2 volts right?
super.. thanks noser =]
Old Feb 22, 2003 | 02:45 PM
elchino's Avatar
Sorry man you're not the first....
But I'm probably not either, been running since about October...can't remember exactly when. Anyhoo, I've got the A/F gauge (look at my sig pick). I can't remember off hand which wire it is, but I'll take a look and get back to you. Also I don't know how you're doing the WOT switch but we had to go with the electronic and tap a wire on the throttle position sensor. And I haven't gotten my window switch running working right yet either. I'm pretty sure I need to get the higher voltage relay (tach adapter is already installed).
Old Mar 4, 2003 | 10:34 PM
WizzaMax's Avatar
any pictures yet or are you going to be running at Fontana Sunday this weekend?
Old Mar 5, 2003 | 09:53 AM
elchino's Avatar
got pics just can't post em on cardomain for some reason. sorry man, I'm not anywhere near California
Old Mar 5, 2003 | 10:44 PM
98maxsel's Avatar
Jime, what are you exactly running to get a 13.1 ??? Can you list mods done when you got a 13.1? intake,full exhaust,75 shot? slicks?
I have a 98 se 5 speed with intake, budget-y, 75 shot, bottle heater, act hdmm clutch. would i be able to get around 13.5-13.7 in 1/4 with street tires? your opinion appreciated.
Old Mar 6, 2003 | 04:14 AM
Jime's Avatar
My mods are all listed in the 1/4 mile times forum. Nothing really special, engine is untouched.
I was only able to run a 13.8 with a dry setup 100 shot. NX is a whole lot different, a wet system will run up to 50% more power than dry and I ran both with the same mods and they are not comparable.
I know I keep harping on wet vs dry but once you have seen and felt the difference you will be a believer. I wish I had of dyno'd both setups just to prove the difference.
You will definately need slicks, you biggest problem will be traction with a 5 speed. I run 22" slicks because the lower gear ratio really helps the auto but will be the enemy of a 5 speed, I would probably stick with a 24-26" slick for the 5 speed.
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
ballerchris510
Sep 10, 2015 09:35 PM
GregL65
Sep 7, 2015 10:33 PM
Justin Kroll
Sep 2, 2015 11:06 AM
