How do you read an EGT gauge?
Old Apr 13, 2003 | 12:15 PM
DCmax's Avatar
The part I'm confused on is that the main n20 writeups (Sx7r and Mardisgras) refer to a normal reading of 800 degrees celsius. My EGT (Pyrometer) reads in degrees farenheit. At idle, I'm at 800 but on the higway at speeds varying between 60-85, I'm between 10-12.
What reading is normal, what's lean/rich?
Here's a pic of mine:
Old Apr 13, 2003 | 09:48 PM
Ramius83
First, where is your probe mounted.....????
Old Apr 13, 2003 | 10:15 PM
DCmax's Avatar
Just as Autometer recommends, about 6 inches down off the front bank.
Old Apr 14, 2003 | 08:02 AM
Ramius83
That is about right. I have mine actually mounted in the front bank header. I read about 1350 at WOT off the bottle. So since you are a little farther down then I am, your readings are fine. Now, when you spray, base your tunings on your current readings to determine if you are running lean or rich.....
Old Apr 14, 2003 | 09:32 AM
DCmax's Avatar
Makes sense, thanks.
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
