60 shot ok on stock Fuel pump?
Old Apr 22, 2003 | 03:57 PM
venompwr2's Avatar
Can the stock fuel pump handle a 60shot? I dont know the max pressure it can handle but a 60 bumps it to approx. 67psi, is that too high?
Old Apr 22, 2003 | 06:44 PM
BJJ's Avatar
BJJ
Re: 60 shot ok on stock Fuel pump?
You should be fine to run a 60-shot on the stock fuel pump, but I wouldn't go much higher. Check your spark plugs to tell if you are running lean or rich, that is the only way to tell unless you have an air/fuel or EGT gauge.
Old Apr 22, 2003 | 07:55 PM
ejj's Avatar
ejj
Wow, not even installed yet and you've got the itch for more!
Old Apr 24, 2003 | 07:51 PM
SR20DEN's Avatar
VQ Wizard
A fresh fuel pump in a A32 will safely handle a 70 shot. If your pump is as old as the car do yourself a favor and upgrade it to avoid a potnetial problem.
Old Apr 25, 2003 | 12:14 AM
DCmax's Avatar
Wow, your pump is still going strong. I could barely hit 50 psi using 50 shot. Needless to say, I upgraded very quickly.
BkGreen97
Apr 2, 2016 05:47 AM
bumpypickle
Sep 20, 2015 08:22 AM
rnb754
Sep 14, 2015 11:39 PM
conansriver
Sep 11, 2015 10:26 AM
