NX kit installed Part Two
Old May 7, 2003 | 09:47 PM
XXXL Cracker's Avatar
Took the day off today and changed my oil, installed my CF door pillars and worked on my NX install.
Part 1:
Ran SS nitrous lines to engine bay. Ran SS line to glove box to connect to my Nitrous gauge.
Drilled holes and mounted bottle brackets. Set up NX remote bottle opener.
Ran wires from engine bay through passenger door into glove box for purge, activation, remote bottle opener and bottle heater.
Part 2 - Today
Installed three fuel tees and connected fuel line to filter. Connected the tees to the stock fuel line. Hooked up Fuel Pressure Gauge, installed nitrous fuel line and FPSS (all mounted, no wiring yet with the exception of the FPG).
Mounted Fuel and nitrous solenoids and purge valve (solenoid and purge line).
Drilled and mounted nozzle and ran all nitrous and fuel SS lines.
Mounted activation switch. I have a VI and had to get a little creative with the Mounting.
Part 3 -
Will be connecting all wiring and hooking up the MSD RPM switch.
Test runs and some fun.
I took a bunch of pics and will post later.
D
Old May 8, 2003 | 04:04 AM
Jime's Avatar
Sounds like your pretty organized Dave. I am still trying to get the wiper blades off so I can get into the rain tray to run my purge line. I need a small puller for the blades, don't think they have ever been off, my 97 they just popped right off.
Old May 8, 2003 | 07:08 AM
Quite honestly, I was pretty overwhelmed at first and wanted to make sure I got everything right the first time.
However, after doing this install it would be very easy to do it again.
That first time is the key...had to pop my cherry
Definitely a DIY'er install. If I had a shop do it, I would not be able to troubleshoot or know what everything is and what it does.
Wiring is next then some testing.
BTW: Where did you get your plugs and did you change the gap? I have a part # for the plugs.
D
Old May 8, 2003 | 03:01 PM
Jime's Avatar
I got them at a local auto store here, they had to order them in, I use BKR7ES gapped at .035. I have a champion sparkplug gapping tool that I got at a snowmobile race in Alberta in 1972. That was long before they started gapping them in the box.
First time is hardest you are right, I think I took just as long this time doing it, just not planning it, I like to take my time and make sure I am not missing anything, I hate surprises.
Old May 8, 2003 | 06:41 PM
TylerBorg's Avatar
i hope i can pull it off
Old May 9, 2003 | 06:34 AM
My concern was the fuel tees and making sure I did not have a leak. A friend of mine has a Mustang that runs mid 12's. The reason it now runs low 12's is he had to put a new engine after a fuel fire.
Burnt almost everything up and thus the new faster engine. His second time at the track he ran 12.6 with slicks.
Anyway, I am going to start with the 35 to make sure all bugs are worked out.
D
Old May 9, 2003 | 07:19 AM
DCmax's Avatar
How exactly are you planning to run your purge line?
Old May 10, 2003 | 04:10 AM
Purge will be on the left side of the hood near the tire.
Old May 11, 2003 | 06:59 AM
Here some pictures from Part 2 of my installation:
Engine Bay
Nozzle Mounting
The Bottle
Enjoy!
D
Old May 11, 2003 | 07:22 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
NOS or NX!!! PICK ONE!!! lol
Old May 11, 2003 | 07:23 PM
Eat Naaawwwzzzzz
NOS or NX! PICK ONE!!!
lol
Old May 11, 2003 | 07:24 PM
Eat Naaawwwzzzzz
lol
WHy dont you purge out between the hood and the windshield...
It looks pretty..
Old May 18, 2003 | 03:48 PM
SonicDust187's Avatar
Did anyone install a filter for the nitrous line on their NX system? Which one do we need?
Old May 18, 2003 | 05:01 PM
DCmax's Avatar
Are you positive you want to do that? I had my purge like that for a couple of months but then it got annoying not being able to see what came out, so I re-routed my purge so it shoots up by my driver's side wiper. I know that's where everyone does it, but it's really the best place for the purge line.
Just a thought.
Old May 18, 2003 | 06:48 PM
elchino's Avatar
Pretty sure ICEMAN from NX is what I have
VQ'ed
69
Aug 27, 2020 12:29 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Team STILLEN
Aug 10, 2015 04:29 PM
