Where to find Walbro 255 High pressure fuel pump?
Old May 16, 2003 | 10:11 AM
DOM's Avatar
DOM
I was hoping that you guys would have some recommendations to where I could buy a fuel pump. I found this site
http://www.importevolution.com/defau...9faf966cf09eef
the prices are pretty cheap. Are any of these the one one that I need?
What about a fuel pressure regulator? Is this necessary, or worth it for the money it costs?
Old May 16, 2003 | 10:37 AM
roastduck88's Avatar
Re: Where to find Walbro 255 High pressure fuel pump?
I'm not sure which one it is on that page but he model number on the fuel pump I got was GS235, (255 lph). I'll have to double check to make sure when I get home.
Old May 16, 2003 | 11:13 AM
xHypex's Avatar
If you want a 255lph HP you want a GSS342. I'm going to try to run one of the new Walbro 190lph High Pressure pumps so that I don't need a new FPR.
-hype
Old May 16, 2003 | 11:24 AM
SonicDust187's Avatar
I think the 190lph will be much better. You will not run too rich N/A and cheaper.
Old May 16, 2003 | 12:31 PM
DOM's Avatar
DOM
I am ready to buy one right now.
Which one is it though?
GSS342 (400-846) Integra 1994-99 255lph-HP
GSS342 (400-848) Miata 1994-97 255lph-HP
GSS342 (400-847) Eclipse 1995-98 FWD/AWD 255lph-HP
GSS342 (400-883) Eclipse 1990-94 FWD 255lph-HP
GSS342 (400-954) 200SX 1995-98 Incl. SE-R 255lph-HP
GSS342 (400-954) Sentra/SE 1998-99 255lph-HP
GSS342 (400-765) Supra 1993.5-98 255lph-HP
Old May 16, 2003 | 12:33 PM
DOM's Avatar
DOM
Whoops!
The mentioned above are fuel pumps with installation kits.
The pump by itself without the kit is what I need right?
Old May 16, 2003 | 01:19 PM
Whoops!
Yeah, since they don't make a kit for the maxima. I just bought the pump itself.
Old May 29, 2003 | 12:10 PM
PCGuRu2K's Avatar
The pump is all you need.. There is a writeup that LatinMax did on 5thgen Walbro install's. You'll need to shave down the tabs to make it fit..
Old May 29, 2003 | 04:00 PM
XXXL Cracker's Avatar
Dom:
I have a brand new one that I never used. I will sell it to you if you want it. Give me a reasonable offer shipped. I will pay for shipping.
dave
Dave
Old May 30, 2003 | 03:19 PM
I had to take out the rubber thing on it to get it to fit along with shaving off the tops. I pretty much had to force it in. If anyone has a solution where u don't have to take off the rubber piece please let me know. Thanks! Otherwise if anyone has any questions with the install I'll be more then happy to help.
Old May 30, 2003 | 03:49 PM
Jime's Avatar
Dom what nitrous kit are you going to use, that will determine which pump I would recommend?
If its dry you need the 255 HP if its wet the 190 regular pump will more than fill your needs and you won't need an aftermarket FPR.
Old May 30, 2003 | 08:52 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
jim, if U go witht he 190 lph, and do not get a FPR, wont I be running rich since the pressure will increase?
Old Jun 7, 2003 | 06:15 AM
JDM4LIFE's Avatar
also on this subject, what is the output on the stock pump? my friend is telling me to get a booster pump instead of an aftermarket fuel pump.
Old Jun 9, 2003 | 11:43 PM
DOM's Avatar
DOM
I am still looking for a pump. I will be using a 70 shot with NOS 5124. Dry. Any suggestions on how far to shave the pump since I have already bought 2 of them and wrecked them?
Old Jun 10, 2003 | 06:53 AM
xHypex's Avatar
How did you mess up 2 pumps already? Also I didn't modify my pump at all. It fits as is inside the holder with just a little bulging.
-hype
Old Jun 10, 2003 | 02:49 PM
-hype
If you have a 4th GEN max, you don't need to modify it if you get the walbro, if you have a 5th GEN max, it's a freakin PAIN IN THE REAR!!! I shaved down all the plastic pieces and also had to take out the black rubber piece. Even then I had to jam that pump in there real tight to get it to fit. It's a MAJOR pain in the rare. If you have patience and alot of time on your hands, (like 4 hours) then you can try it. But if not, get the booster pump instead, it costs 2x as much but is much easier.
Old Jun 12, 2003 | 05:38 AM
PCGuRu2K's Avatar
Yeah I gave up on my Walbro pump install. Was a PITA.. So I'm using the inline Hobb's switch instead.
00MAXI
Sep 2, 2015 10:23 AM
Andy29
Aug 31, 2015 01:59 PM
homewrecker
Aug 24, 2015 08:56 PM
Professor
Aug 21, 2015 07:36 AM
altome15
Aug 10, 2015 07:05 PM
