Medical Grade nitrous oxide
Old May 16, 2003 | 11:11 PM
ToYLeT902's Avatar
JET Speed Lab
can medical grade nitrous oxide be used instead of the nitrous that you get at speed shops?
is it the same except the ones at speed shops put sulfer in the nitrous?
Old May 17, 2003 | 05:35 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Medical Grade nitrous oxide
stealing from the hospital, tsk tsk lol.... I can picture you filling up your bottle lol..
I don't see why it couldn't be used... same stuff.
Old May 17, 2003 | 08:06 AM
TylerBorg's Avatar
I too was wondering this... The speed shops use Nytrous with sulfer so you dont inhale it right? Instead of the Nitrous you would find medically...?
Old May 17, 2003 | 12:36 PM
chinaonnitrous1's Avatar
nitrous baloons! mMm
Old May 17, 2003 | 06:12 PM
SLC I30t's Avatar
I asked this once before, and I was told that unless you have a pump to put it into your bottle that you would have to freeze the hospital bottle and run a line down to the 10lb bottle. I dont know... I'm too lazy to erase what I've written, but the answer is yes, but it would be really difficult to fill the 10lbs bottle completely.
Old May 17, 2003 | 11:20 PM
ToYLeT902's Avatar
JET Speed Lab
one of my friends told me that i could just use a straw, inhale, then blow it out into my 10lb bottle? you think that will work?
J/K!!!
Old May 18, 2003 | 12:01 AM
J/K!!!
no no no...you put it in a baloon..inale..exhale..do that as many times as you can.
Old May 18, 2003 | 10:47 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
i wonder what would happened if you inhaled the sulfer, lol
Old May 18, 2003 | 11:36 AM
ToYLeT902's Avatar
JET Speed Lab
so it would work right?
Old May 18, 2003 | 02:35 PM
SLC I30t's Avatar
Like I said with out a pump, you would have to freeze the tank to lower slow the molecule so when it thaws, I assume that it will create more pressure (I think) kind of away to cheat the system. If you have search capabilities, I asked this question last fall and I think Jime or jaime cbr900 told me about how to do this.
Old May 18, 2003 | 02:38 PM
ToYLeT902's Avatar
JET Speed Lab
oh ok.. and the pump station thing cost a lot anyway.. o well thanks
Old May 18, 2003 | 02:44 PM
SLC I30t's Avatar
what kind of pressure do those little tanks hold anyway? Maybe we could just hook it up to a 4AN connection.
Old May 18, 2003 | 02:47 PM
ToYLeT902's Avatar
JET Speed Lab
no idea
Old Jun 5, 2003 | 09:39 AM
irvine78's Avatar
i think it'd work alot better since the medical grade has no sulfur in it. cars will love it!
Old Jun 13, 2003 | 07:08 AM
Ramius83
I was told that the actual chemical makeup of the two different types are, well, different. If I find my NOX installation manual, I will post on here what it says about the difference between the two.
Old Jun 13, 2003 | 07:25 AM
plurco's Avatar
yes you can use it. There is a gas station around where I live that has a nitrous fill station, and somehow thay managed to get the hookup on medical grade nitrous. It is better because sulfer is am oxidizer. Either that or you can have one big azz whipit!!!:-)
Old Jun 13, 2003 | 09:51 AM
pMB's Avatar
pMB
hmm
you telling me that me and my buddies with a chevy truck can go in to chemistry building at Univ. of GA and take the big a@@ N2O tank and use it to refill??
alright, who's in? I go back to school on August 16th-ish. Help me out and I'll split Nitrous fair, like Robin Hood.
Old Jun 18, 2003 | 06:38 AM
SR20DEN's Avatar
VQ Wizard
There is absolutly no performance difference between medical grade Nitrous and Nytrous Plus. There was a speedshop local to me that was selling medical grade and no one knew nor did anyone mention a difference. Nytrous Plus does contain sulfur but it's such a small amount that it does NOTHING to hurt performance. Read your bottles and you will see that it says "Contains less than 100ppm sulfur dioxide" . 100ppm means 100 parts per million or .001% or one ten thousanth of the total volume is SO2. It's only just enough to turn your brain into jello if you inhale it too many times. I have heard rumors of people inhaling this stuff to the point where they end up in the hospital as a vegetable. Im not certain it has happend but I am certain it can happen.
Old Jun 18, 2003 | 09:44 AM
ToYLeT902's Avatar
JET Speed Lab
finally the answer i've been lookin for.
pssst wanna install direct port in my 2k1? after seeing ur engine bay i decided to close my hood with my simple dry set up
Old Jun 18, 2003 | 09:57 AM
SR20DEN's Avatar
VQ Wizard
I still have to finish mine. It wasn't supposed to make anyone cloe their hoods. It was the only semi cool thing I had to show off since the car looks all stock (except for the slightly lower ride height). I missed out on meeting a lot of people there. Did I miss you too?
Old Jun 18, 2003 | 10:00 AM
ToYLeT902's Avatar
JET Speed Lab
Yup, i was lookin at your car and there were a bunch of people standing around, i didnt wanna go up to everyone and ask if it was there car or not
oh well, maybe at the next meet
Old Jun 18, 2003 | 10:07 AM
SR20DEN's Avatar
VQ Wizard
I think alot of people didn't know who's car it was.
Apr 16, 2020 05:15 AM
97_GXE
20
Sep 17, 2015 08:12 PM
4 door GT-R
Aug 22, 2015 07:50 AM
Ramius83
Jan 5, 2001 03:31 PM
