zex nitrous in SE-L?
Old Aug 12, 2003 | 03:35 PM
J 9MAX9's Avatar
i have been running a 65 dry shot of ZEX nitrous in my 99 SE-L for almost a year... I've only used it like 8 times, but i'm upgrading to a 75 shot. Until now, the only other mod i've made for the nitrous is colder plugs. With the upgrade to a 75 shot, i'm replacing my fuel pump with an external Holley pump. Is this the only thing i need, or am I forgetting something? And if i were to run a 100 shot, i would have to switch to a wet setup, correct? TIA, i haven't really seen a lot of nissan's with the zex kit, so i'm not sure how it works...
-Jon
Old Aug 12, 2003 | 03:56 PM
CalsonicSE's Avatar
If you have a high flow fuel pump, you won't need to switch to a wet setup; a high flow pump (e.g. Walbro; however, I don't know the specs of the Holley pump you are planning to get) will put out more than enough fuel pressure to handle a 100 dry shot. In fact, I've been spraying a 125 dry shot for several months now with no problems - plugs & A/F ratio on the dyno look good.
jerrod99_se-l
Aug 22, 2015 04:14 AM
SethMax
Jan 2, 2001 10:28 PM
DavidMaxum
Dec 29, 2000 04:36 PM
My 4DSC
Nov 3, 2000 08:23 AM
