zex kit install, need help ?????
Old Dec 1, 2003 | 11:27 AM
nightryder's Avatar
ok this zex kit is just a standard zex kit that has the nitrous managment unit. i'm going to be installing it in a 94 maxima but i wasn't quite sure how to hook up the regulator line and intake line off the unit. this kit is a wet kit but it only has the nitrous hose going into the intake. i figure it uses the stock fuel system to add the extra fuel but i'm not sure where or how to connect the regulator and intake lines.
Old Dec 1, 2003 | 01:36 PM
nightryder's Avatar
"I need to read the FAQ and IMPORTANT threads before posting a question" yeah i just noticed that. it's real mature considering i did and nothing helped. and i can't even change it back. wow is a 16 yr old running this board or something.
Old Dec 1, 2003 | 01:43 PM
BJJ's Avatar
BJJ
First off if you read them again they can help you out alot, second if the Zex kit you have only has the nitrous line coming out of the nitrous management box than it is a DRY kit not a wet kit, the dry kit provides extra fuel by bumping up the fuel pressure when you spray which is controlledby the zex box through the vaccum line that goes into the fuel pressure regulator, but you would know this if you had read the FAQ's.
Old Dec 1, 2003 | 01:53 PM
nightryder's Avatar
ok i see some pics of the unit under the hood of some cars NOT where the lines are hooked up to the intake and regulator, and there is no info on that. oh and it IS a wet kit. i'm not stupid like you seem to think, i've hooked up nitrous kits before just not the zex kit with the managment unit. and did i say that there was one line, hum no it has the nitrous in and out, the regulator line and the intake line. i know how the kit works i just want to know where to hook the lines up to a 94 max
Old Dec 3, 2003 | 05:55 AM
SR20DEN's Avatar
VQ Wizard
There is no regulator line in a wet kit. Again you described a dry kit.
What is the Zex part number of your kit and does it have Fuel in, Nitrous in and Fuel out, Nitrous out?
MaxLife17
Jun 27, 2019 01:37 PM
mpbclutch33
Sep 8, 2015 06:21 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
