can a nissan oem clutch hold 75 shot and all bolt ons?
60-75 shot + bolt-ons on oem clutch....won't last very long at all. I'm proof of that. My oem clutch lasted an estimated 20 1/4mi runs before it was showing signs of slippage. That's roughly 1/3 of the race season round here.
well...im only going to be using it in gear. not like in between gears, when there would be a huge problem with tearing up the clutch...so when fully engaged and in gear, a 60 shot of nitrous would tear up my clutch? even when never using it in 1st? then why would a aftermarket clutch last longer...just because it has higher gripping force and not because it is any thicker? i don't understand why if a clutch was gripping absolutely in any gear....and you spray, and the clutch appears to be still gripping absolutely, then there is any more wear occurring!!!???....except if you spray then it starts slipping then obviously there is extra wear happening....but clutch wear is mostly because of launching and shifting...not in gear...there is barely any in gear...so spraying in gear....would cause micro slips even on a 60-75 shot that would accelerate my clutch wear is what your saying?
SmoothMax, i looked at your car domain page, the 12.99 tuned 110 shot is on drag slicks or street tires? and where did you have it tuned, dyno? or just SAFC? or did you actually have your ecu tuned for it?
vingodine
45
May 21, 2016 12:46 PM
carlosvq30
Aug 17, 2015 11:32 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
