Just had a nitrous scare!!
Old Mar 16, 2004 | 02:54 PM
99maxx-on19's's Avatar
well i just installed my nx kit and was on my way home when i ran into a friend who wanted to see my set up and showed him and turned on my bottle but about 20 min later my car started to pull and rev high?so i pulled over and i could here it spraying so i ran and closed the bottle watied a while and everything was ok.But i'm scared to open it has anyone had this happen to them?Or is something wrong with the set up?also i don't now much about this kit and was wondering what pills to put in my kit,because my friend who installed my kit didn't know and put 2 but i don't know if i'm runnin the right pills.As of now the extra pills i have are 24, 31, 41, 22, 20 Can someone help me!
Old Mar 16, 2004 | 02:55 PM
I'm trying to run a 50 shot but don't know what pills are in now
Old Mar 16, 2004 | 04:39 PM
Jime's Avatar
Old Mar 16, 2004 | 05:28 PM
SonicDust187's Avatar
I think you installed the wot switch incorrectly.
Old Mar 16, 2004 | 06:21 PM
CullenJ76's Avatar
uhhhhh, either you had some extra pills or else your are running a friggin 125 shot
sounds like you reversed the polarity on your micro switch(wot switch) to where it's on all the time
i would not even dare arming the system until you find out EXACTLY what jets you are using.
Old Mar 16, 2004 | 08:51 PM
Nismo's Avatar
is it possible that the solenoid can be stuck open or partially stuck open?
Old Mar 17, 2004 | 02:43 AM
CullenJ76's Avatar
it's possible, but That would be an electrical wiring problem really, because the solenoids can't open without a signal. Just like a bottle heater, the solenoids have two wires coming from them, but it does not matter which is ground or power, so I'd say it's an improperly wired micro switch, toggle switch, or maybe even the relay.
on 19's: was this a new kit?
Old Mar 17, 2004 | 04:40 AM
plurco's Avatar
you can not reverse the polarity of the micro switch. it is non polar. it mearly breaks a circuit.
Old Mar 17, 2004 | 01:09 PM
yeah its a new kit im going to put in the right pills but what does (wot?) mean?
Old Mar 17, 2004 | 03:08 PM
stupid noob question i should of thought before i said anything, wide open throttle duh and i put in the right pills i was runnin 35 n2o and 18 fuel..but i noticed something that the line coming from the fuel solenoid went into the n2o line on the intake and n20 line went into the n20 solenoid they look crossed but i need someone to look at this!
ColdCananda
Sep 20, 2015 10:45 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
