Can a dry NOS kit be used on a 2K2?? Wanna make some $?
Old Dec 10, 2004 | 03:53 PM
RKS's Avatar
RKS
If it can I am willing to meet someone and pay them for help in installing it. I live in the Cincinnati area.
Old Dec 12, 2004 | 07:38 PM
TAPOUT's Avatar
You will lose
Yes it can, about 50-70hp would be the limit without other mods. Change the plugs, and let it go. You need to make your own WOT switch, cause I think 2k2 is drive by wire. I am a little farther than the average distance to travel for an install, so good luck.
Old Dec 12, 2004 | 07:46 PM
SR20DEN's Avatar
VQ Wizard
Having personally written the book on how to do the dry nitrous install on a 2k2 I personally do NOT recommend it. The VQ35 does NOT have a fuel return line which makes the task really not worth trying. You're better off using a NX or Zex wet kit. They're both reliable and are far easier to install on that vehicle. As for the DBW, it doesn't mean anything. You just install the WOT switch on the gas pedal. And with the Zex kit you get the TPS signal from the TPS on the gas pedal or at the ECU.
Old Dec 12, 2004 | 07:55 PM
RKS's Avatar
RKS
I think I remember you trying this when the 2k2 were just hitting the market and the return fuel line is what prompted my question. I had originally bought this kit for my 95 and never used it, I guess I'll just have to sell it now...unless I can put it on my Armada
thanks for the help guys
Old Dec 12, 2004 | 08:10 PM
SR20DEN's Avatar
VQ Wizard
Originally Posted by RKS
Iunless I can put it on my Armada
I just looked at the Titan ESM and it appears to be the same returnless setup.
Old Dec 13, 2004 | 08:05 AM
Bluebird's Avatar
I am Roid Rage
Should you decide to get another kit, I know a good installer in Boardman, Ohio.
Old Dec 19, 2004 | 05:24 PM
TAPOUT's Avatar
You will lose
My bad, I forgot 2k2 changed the fuel system. If you just get one more solenoid, you could plumb it into the fuel line, get a new nozzle, and make it a wet kit...
I<3 A32's
Sep 10, 2015 11:07 AM
Vequity
Sep 10, 2015 05:26 AM
mpbclutch33
Sep 8, 2015 06:21 PM
A32goldylocks
Sep 2, 2015 06:39 AM
