Fuel Pressure
Old Jul 14, 2005 | 03:20 PM
JUICED's Avatar
Fuel Pressure
I'm ready to install my Walbro 255 fuel pump & Sards fuel pressure regulator. My question: What should the fuel pressure be at idle and at wide open throttle? I also could use your advise: The Sards fpr has an additional port on it and I'm wondering what I can put there - nitrous feed line, fuel pressure guage, etc. What would you use it for? If there is anything else I should do or if you just want to give me general ideas/advice your more than welcome. I should be installing these two parts on Tuesday of next week so any help would be very helpful and appreciated. Thank you! BTW - A week after I put in the pump and regulator I will be installing a ZEX wet kit running a 75 shot.
Old Jul 14, 2005 | 04:11 PM
SonicDust187's Avatar
34 at idle, 43 at wot.
Old Jul 14, 2005 | 06:53 PM
JUICED's Avatar
34 & 43 is the stock setting though. Don't I have to push out more fuel?
Old Jul 14, 2005 | 10:26 PM
No, wait. You have a 5th gen, I do not know what your # should be. However, you want your car to idle at what ever your stock fp is.
Old Jul 15, 2005 | 08:12 AM
grey99max's Avatar
LandShark has Cosworth
What Happens When-------
Another related fuel-pressure question:
I was planning on installing my Walbro 255 HP pump and Aeromotive (? sp) regulator this weekend, but now I'm not so sure. I think that when the walbro is installed by itself, the pressure and volume from the pump will overwhelm the stock regulator.
The idea behind the new regulator is to cap-off the higher pressure by bypassing the extra fuel back to the tank, to the pressure manually set in the new regulator.
But what happens to the 34-43 psi change in fuel pressure now controlled by the stock 4th-gen regulator? Will the pressure stay at the Aeromotive's set point and not change to follow the stock pressures? If I set the Aeromotive to 43 psi, will the pressure stay there? This regulator is a bypass-only regulator with a high internal volume and a turbo pressure port which raises the pressure 1:1 with boost, but no vacuum sensing to drop the pressure.
Is this the wrong regulator for the walbro 255 HP??
Old Jul 15, 2005 | 03:16 PM
JUICED's Avatar
So does anyone know what the fuel pressure should be for a 5th gen using a 255 and Sard fpr?
Old Jul 16, 2005 | 06:03 PM
grey99max's Avatar
bump on the fuel-pressure and regulator questions.....
Old Jul 16, 2005 | 07:31 PM
NisMo-Max's Avatar
JuIced, what was is the part number on the walbro 255 fuel pump, because i looked on the website, and they dont have the application for the 5th gen. Thanks...
Old Jul 17, 2005 | 12:00 AM
2k use the same pump as the 4th gens, however something on the pump needs to be cut off to make it fit into a 2k maxima.
Old Jul 17, 2005 | 04:28 PM
JUICED's Avatar
GSS342 is the Walbro part number for the 255 Iph high pressure fuel pump
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
