NOS in 6th Gen
Old Jul 20, 2005 | 07:25 AM
  #41
Deckdout2's Avatar
Play with my balls
Originally Posted by Tek-Niq
where is everyone getting these cold plugs?
Clubplug.net.....I got mine at a local shop for a few bucks cheaper.
Old Jul 20, 2005 | 08:29 AM
  #42
vq356sp's Avatar
El Mas Noob Del Org.
i got mine from sparkplugs.com they are fast i got mine in one day check em out
Old Jul 20, 2005 | 09:09 AM
  #43
ramberg's Avatar
GrandPa
I checked this out on sparkplugs.com Since I am not going to go crazy with the nitrous it seems I only have to use Iridum plugs. Warren
Nitrous Oxide is an efficient means of getting more oxygen into the combustion chamber. Initially the
N2O injection will cool the incoming charge due to the energy expended on vaporization into the air fuel mixture. However, do to the dramatic increase in power output, the sustained use of N2O increases cylinder temperatures to the point you may require a spark plug one or two heat ranges colder. If the nitrous is used only for very short bursts, (less than 10 seconds), then the standard plug can likely be used with no spark plug heat change necessary. It is not suggested that platinum spark plugs be used with nitrous systems. HOWEVER, we have had no reports of any problems using Iridium plugs with nitrous injection.
Old Jul 20, 2005 | 03:28 PM
  #44
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
this group deal looks like is still on and the prices are the same Ramberg, check it out..
http://forums.maxima.org/showthread....2&page=1&pp=40
Old Jul 27, 2005 | 02:14 PM
  #45
Crazy-J's Avatar
On my Sentra Spec-V we slapped a 100shot on it with stock fuel pump, same plugs, nothing done to the car other than the 100 shot and the motor took it. We were trying to blow up the motor since I'm now doing a VQ35DE swap.
It just doesn't make sense that the stock fuel pump can't handle a 75-100 shot. I have put nitrous on quite a few cars. From Kia's to Nissan's and I have never had a problem with lean conditions due to stock fuel pumps not being able to handle a 75 shot.
We were going to put a hundred shot onto the VQ but now I'm not so sure.
Old Jul 27, 2005 | 05:02 PM
  #46
SR20DEN's Avatar
VQ Wizard
Within a couple of years that will be the next big thing. The Honduh people aren't going to be happy about it and they'll cry about it as they do everything else that doesn't pertain to them.
Old Jul 27, 2005 | 07:10 PM
  #47
Crazy-J's Avatar
Yeah I will be selling a bolt on kit for it so we may see quite a few! The Honduh boys are already jealous.. I mean hell look at every other makers line up. lol!
Old Jul 27, 2005 | 07:12 PM
  #48
SR20DEN's Avatar
VQ Wizard
Bolt on to what, the hood?
Old Jul 27, 2005 | 07:17 PM
  #49
Crazy-J's Avatar
I'm putting together the mounts,wiring harness, CAI, slim fans, and everything else needed to make this swap just a bolt in affair. No customization required.
John
Old Aug 17, 2005 | 02:40 PM
  #50
akaxmrxhammer's Avatar
tek and ramberg... did you guys find out more info on the nitrous?
imported_Nismo_max
Sep 21, 2015 07:24 PM
Max139617
Sep 20, 2015 07:09 PM
hot04
Sep 18, 2015 06:14 AM
240tomax
Sep 13, 2015 03:28 PM
