1100psi and wantin more...
Old Sep 3, 2005 | 06:50 PM
99Maxxx's Avatar
aight, so i sprayed my car for the first time thursday night.....and its freakin awesome. i went from running a 9.53 @ 78 to running a 9.31 @ 88.1. not a bad improvment for a 40 shot. my question is the obvious one......how in the hell do you control wheel spin? I mean, sure....im running 17x7 Konigs with 245/35 tires, but is there any way to fix this?
Old Sep 4, 2005 | 12:09 AM
Brushedpewter's Avatar
Get slicks and a nitrous controller unit.
Old Sep 7, 2005 | 03:57 PM
99Maxxx's Avatar
any idea what size slick or dr i can run with those tiers and a car thats lowered almost 3 inches? I mean, all of my racing group drive mustangs, and im sure that a 245/45 will fit in the fenderwell but could somebody with 1st hand experience give me a hand here?
Old Sep 12, 2005 | 05:22 PM
LT1PnyKlr's Avatar
I would just look into a good drag radial that will be street friendly as well. Possibly a Nitto or BFG drag radial. Nitto will last longer on the street but the BFG will bite harder at the track.
Old Sep 15, 2005 | 08:46 PM
TAPOUT's Avatar
You will lose
Up your jet size to about a 80 shot, that will really get you addicted.
Old Sep 20, 2005 | 08:50 PM
LT1PnyKlr's Avatar
Im not really familar with Infiniti's and Maxima's too much. I just bought a 99 Infiniti I30 and still have my 97 Camaro Z28. I am used to spraying 150 shot on her but with other upgrades such as ignition and bigger fuel pump. Not sure about these motors though and what they can handle.
Old Sep 20, 2005 | 09:48 PM
mtrai760's Avatar
'Trynna' is not a word
There are a few that have tried the 150 shot on the Max, but not too many. Deffinetly not for the faint of heart.
Old Sep 21, 2005 | 02:03 PM
ajsince81's Avatar
I've been running a 75 shot for about 8 months now on a stock motor except for more nitrous friendly spark plugs then what it comes with. I have not seen a problem yet. Planning on jumping to a 100 shot.
Old Sep 22, 2005 | 12:13 PM
C MAX's Avatar
dont use it off the line. slicks or dr's will definitley help but still give you a little spin unless you work it right. i would try spraying in 2nd and up.
Old Sep 24, 2005 | 05:13 PM
TAPOUT's Avatar
You will lose
I'm one of them....It's such a rush to light up the tires at 60 mph on the highway ....I mean drag strip. Last year I was running 80 shot dry for stage 1, and 150 wet for stage 2. I was running 8.6 in the 1/8th, and low 13's in the 1/4 on just the 80 shot. I never ran the 150 at the track. I'm putting the nitrous back on after I get my Mustang back on the road.
Old Sep 28, 2005 | 01:30 PM
Jason R's Avatar
aka UNCDooD
oh jason if i do recall you never made a low 13 second pass on nitrous. I remember you saying your best was more like a high 13-second pass.
Old Sep 29, 2005 | 12:31 PM
Blu's Avatar
Blu
the tits
Im sorry but a 10mph improvement from a 40 shot is BS. What other mods on the car and was this at a track or on a stupid g-tech?
Old Sep 29, 2005 | 07:02 PM
TAPOUT's Avatar
You will lose
I was able to run on one of those "unapproved" asphalt places, and pulled a 13.2 on the slicks. Nobody will know the full details....Remember at the approved race track, I ran a 13.7 with a 2.25 60ft time. I also was able to get the slicks properly heated, and pull a 1.84 60 ft on the unofficial time. I must admit, this was with my G-timer, but it has never been off by more than .08 in the 1/4 mile.
Old Oct 27, 2005 | 11:30 PM
99Maxxx's Avatar
What other mods do you have running that 8.6? I mean, thats exactly where I want to be with mine if at all possible
Old Nov 5, 2005 | 08:00 AM
TAPOUT's Avatar
You will lose
UR UDP, 70mm TB, ported to match intake manifold, Place Racing CAI, Stage 2 VB, Warpspeed Y-pipe, Greddy SP-1 Cat back, 2 step colder plugs, KYB GR2 shocks/struts, Eibach Pro kit springs, Walbro255 fuel pump, Cool Can for fuel, oil cooler system. 80 shot nozzle was 4 inches before the TB.
Old Nov 5, 2005 | 10:45 AM
KsuMax's Avatar
Cheesing away...
For less wheelspin, don't spray out of the hole and learn to drive better.
Old Nov 7, 2005 | 09:41 AM
95maxrider's Avatar
Lightly modded
Am I the only one who was told that running over like 1000 PSI could do more damage than good? I mean sure, you might get away with it for a while, but why not do it properly and get a bigger jet, etc....
Jason(Tapout)- What's the deal with your Max? Is it running? Spraying?
Jason(UNCDooD)- I thought you were selling your car?
And to answer the question of the poster......follow the advice of KsuMax. Don't spray out of the hole unless you got slicks and lots of practice. Try and wait until 2nd, you might end up running faster in the end.
Old Jan 10, 2006 | 11:32 PM
Donkeypunch's Avatar
The bottle can handle 1000 pretty well.
Traction issues? Get rear wheel drive
Old Jan 11, 2006 | 12:09 AM
99Maxxx's Avatar
Well I did alittle better this time around...I went to the track Sunday and managed a 9.11 @ 81 but had a pathetic 2.3 60' and only around 500 psi in the bottle. Stupid 60 degree weather and no bottle heater will do it though.
I can't wait to spray this thing after I get my VI installed. I'm sittin here looking at it in my living room...it needs to not be here
For Tapout - I went to a Walbro distributor's website and found no pump listed for a 99 Max. They show 89-94 as well as a few other Nissans. Do you remember the exact part # for yours? Check it out and you'll see what I mean http://www.nolimitmotorsport.com/walbro/
Old Jan 11, 2006 | 06:18 AM
Blu's Avatar
Blu
the tits
81mph traps is a lot more realistic than the 88mph in your first post. Must have been a typo or an inaccurate timeslip.
Old Jan 13, 2006 | 09:57 AM
TAPOUT's Avatar
You will lose
You mean ....For slower times...Don't spray out of the hole. Try slicks that are heated, and shut it. Look at Mustangs running 7's in the 1/4 on drag radials.
95...My Max is running good, just ordered new parts from Corey, putting spray back on after Mustang is done.
Walbro 255 high pressure pump. Of course it is not listed, it is way more than the stock system should endure. You could also use the 190 low pressure pump, as it is designed for more volume, less pressure.
Old Jan 13, 2006 | 10:08 AM
99Maxxx's Avatar
Yeah, I knew that we were talking about the 255, but my question is, if I wanted to order one for my car, I don't see one listed here.
Now I know this isn't ever pump made, but I don't have a clue what the part number is on the one that fits our cars.
Old Jan 13, 2006 | 10:46 AM
C MAX's Avatar
well i have the gss342 walbro and its a direct fit replacement.
Old Jan 13, 2006 | 11:55 AM
Jime's Avatar
You want the one for the 95-99 Eclipse, I have used it on 2 different Maxima's.
Old Jan 13, 2006 | 11:57 AM
99Maxxx's Avatar
And will just any of the universal FPR's work or do you have a recommendation Jime?
99Maxima5sp
1/4 and 1/8 Mile Racing
31
Nov 14, 2003 07:08 PM
Gooey
Oct 3, 2003 06:54 PM
Gooey
Sep 22, 2003 08:17 PM
ZeRo MaX
Tires and Wheels
Sep 13, 2003 08:59 PM
phast92se
23
Jun 10, 2003 11:42 PM
