i hope someone knows the answer
Old Sep 7, 2005 | 09:18 PM
xlcrew's Avatar
I’m Back
ok i bought a used kit off a buddy of mine. it's got everything i need. it's a NX wet set up. it came with a fuel pressure part that i guess reads the fuel pressure and if it senses a drop in fuel pressure it drops the nitrous so i won't spray under a lean condition. my question is how do i wire this into the set up. I've figured out that the way to go is from the battery through a fuse to the arming switch, to the wide open throttle switch and then to the siloniods(not sure on spelling for that). please some one tell me if i'm correct on this. i've looked at the diagram that is in the FAQ section. and i'm guessing that when i wire in the siloniods that i also wire in the fuel pressure part? so that it cuts the power to the silonoids? i don't mean to sound stupid here and i hope that i don't. trying to save me some money and i'm pretty mechanically inclined. thanks for the help
Old Sep 8, 2005 | 12:38 AM
mtrai760's Avatar
'Trynna' is not a word
The fuel pressure safety switch simply provide a ground. You can hook it up to the ground on the nitrous solenoid, or the relay ground. Here is a diagram from nitrous express:
btw, nitrous express has installation instructions on their website. They are not maxima specific, but they will get you by.
Old Sep 8, 2005 | 10:12 AM
xlcrew's Avatar
I’m Back
thank you very much, that is exactly what i needed
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
bernyp
Oct 2, 2015 10:10 AM
