I read the stickies but....
Hey guys ive read all the stickies but im worried about getting nx wet kit for my auto because if i sprayed during the shift couldnt that **** up my trans.I wouldnt use wot switch,just a push button. But yea anyone running a kit with auto or could tell me about it.
when I was running a 55shot I would spray thru the shifts with only the drop mod no problem, but when I went to a 75shot I notice the shifts would take alittle longer and had to add a tranny cooler and moble1. now I can chirp or sometimes spin 2nd gear and the tranny does not over heat
I also added a msd rpm switch cause when I go to a 100shot I will set the nitrous to turn off at 6500rpm so the tranny can shift
So,The nitrous will only come on on wot if i have it opened and set to be used?And i Planned to get a tranny cooler anyways so ill just get it all when i gets a kit.So use a tranny cooler,use wot setup and get rpm switch to cut it off,Personally id set the rpm to 6100-6200.Dont want to **** my motor.
my rpm switch and tach are about 100rpms off, I made a few passes with a 75shot and with the moblie-1, tranny cooler and drop mod it shifts about 200-300rpms faster than without the tranny cooler and moblie-1
so yeah your right with the added 25hp I'll take it down to 6300 or 6400rpms
mkaresh
Mar 12, 2018 06:48 PM
