Bottle heater
Old Oct 1, 2007 | 02:12 PM
rockfordmaxII's Avatar
Bottle heater
So I am in the market for a bottle heater. I was wondering how the automatic heaters work vs. the manual ones. Im wondering if it really is worth the extra money for the auto. From my knowledge, the auto one will keep the bottle at a constant pressure. The manual ones, if you turn it on and leave it on, will it only heat it to a certain pressure? or will it keep going and possibly cause problems. Im not too sure what im askin here lol. How long does it usually take for a heater to totally kick-in. How long does it take to fully heat the bottle to max psi?
Old Oct 1, 2007 | 04:38 PM
absoundlab
go with a zex heaters its 90 dollars online and its way easier to use
Old Oct 1, 2007 | 07:23 PM
will that work with my system even though i do not have a zex system? just to make sure because im not familiar with the zex system's.
Old Oct 1, 2007 | 07:27 PM
http://cgi.ebay.com/ebaymotors/Nitro...QQcmdZViewItem
Would these switches that are missing be just like any other toggle? And do i need the blow down tube? isnt that the same thing that goes from the bottle to outside in case the bottle pressure gets too high? So this is an incomplete kit that would be really easy to complete right? just a few toggle switches. and where have you found it for $90?
Old Oct 2, 2007 | 07:19 PM
anyone?
Old Oct 2, 2007 | 07:32 PM
t6378tp's Avatar
Turbo 3.5
do not get zex it sucks, buy a warmer that works off of psi not temp
zex works by temp and there are times that the correct temp is met but it's still not at the correct psi
but if you really want a zex warmer you can but mine for cheap
Old Oct 2, 2007 | 08:38 PM
i dont particularly want one brand or the other. im just wondering how exactly it works. and which is best to buy
Old Oct 3, 2007 | 01:33 AM
mastercater7's Avatar
VQ35 FTW
the best to buy is the dynotune kit. its a pressure sensitve switch which connects to the bottle before the nitrous line to the solenoids. once pressure reaches the set psi, the heater shuts off and as soon as nitrous psi drops, the heater auto clicks back on. it is the best heater out there, heats fast and precise. A buddy of mine has the zex and its no good. Also you could probly get them to bargain the price down. hope this helps man, i believe theres pics of the switch in my car in the sticky.
Zack
Old Oct 3, 2007 | 08:25 AM
dynotune kit is $119. good price? should i call to see if they can give me a little more off? If so, should i just tell them that im with the org or what?
Old Oct 3, 2007 | 05:19 PM
t6378tp's Avatar
Turbo 3.5
psi > temp
Old Oct 3, 2007 | 11:36 PM
VQ35 FTW
tell them you cant quite afford it, you might could work it. but its the best kit.
Old Oct 12, 2007 | 11:52 AM
blemished one for $99 shipped, yay!
howardis
Dec 11, 2019 06:10 PM
220k+ A32
Sep 23, 2015 03:38 PM
RWCreative
Sep 21, 2015 11:01 AM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 7, 2015 04:20 PM
