nitrous newbie help !!! well not too much of a newbie
Old Sep 18, 2008 | 06:00 AM
  #41
MaxdFactor's Avatar
Originally Posted by t6378tp
I ran a zex dry kit and I max'd out the injectors with a 100shot and a walbro pump. I have dyno proof to back it up, I would not suggest going over a 55 shot with stock injectors and pump. And 65shot with stock injectors and a walbro anything beyond a 75 shot you should get either bigger injectors or convert to a wet kit which is what I did and picked up another 38whp
I'll try it with the Walbro pump...already running Zex Hyper-performance plugs, hopefully that will get me to the 75shot safely...Any specific model for the Walbro pump???
Old Sep 18, 2008 | 07:06 AM
  #42
C MAX's Avatar
i really wouldnt suggest running a 100 shot dry, really. even though you have enough pump power the injectors are gonna freeze up at some point from too much pressure. i tried it,lol and it finally ended with bad results. but the gss342 is the best one if you wanna try it. i managed to run a long time with a 75 shot and though 25 more hp wouldnt hurt but it did,
Old Sep 18, 2008 | 08:06 PM
  #43
MaxdFactor's Avatar
K...thnx CMax...getting to the 75 shot was my goal...so i'll check on that pump. So thats the only change i need to make?..sounds easy. Only the Dyno will tell.
Old Sep 18, 2008 | 08:31 PM
  #44
t6378tp's Avatar
Turbo 3.5
your going to up the shot trust me, just save another 120bucks and convert to a wet kit
it's easy I pretty sure I even have my parts list
Old Sep 19, 2008 | 04:00 AM
  #45
C MAX's Avatar
yeh exactly, 100 shot wet is lovely lol
Old Sep 19, 2008 | 07:25 AM
  #46
MaxdFactor's Avatar
Nissan told me the pump is in the tank? You guys have any pics of ur fuel pump swap out? Some visuals wud be helpful..thnx
Old Sep 19, 2008 | 10:46 AM
  #47
C MAX's Avatar
it's very simple, underneath the back bottom seat is 2 latches, pull them out and pull up the bottom seat and take it out. the pump is right there in the middle, take off the cover and make sure you have a replacement o ring and remove the pump. the hardest part to me was getting off the hoses sometimes they are on there tight.
Old Sep 21, 2008 | 07:27 AM
  #48
MaxdFactor's Avatar
Kool..thnx...sounds simple enough...been workn on my house so the Max will get a new pump and 75 shot next weekend. Thnx CMAX, if i've got any questions i'll hit ya up.
Old Sep 22, 2008 | 01:42 PM
  #49
nwell2k3's Avatar
Always use protection when playing...
halfpol
Oct 17, 2022 12:16 PM
RinconI30
Nov 10, 2015 10:55 PM
JMag90
Aug 25, 2015 09:17 AM
halfpol
Aug 5, 2015 08:24 PM
ed571
Dec 29, 2000 08:04 PM
