? Use nitrous to override the factory rev limiter ?
Old Feb 22, 2014 | 09:56 AM
  #121
Fakie J Farkerton's Avatar
Originally Posted by grey99max
Oh Hell No ! Never purge into your engine - that's like using # 9999 jets to spray with. You'll be a basket case if you do this - you'll be using a basket to gather up all the engine parts from the explosion... Super lean condition instantly...
Old Feb 22, 2014 | 11:36 AM
  #122
ABIGBRAIN's Avatar
In the final 20 seconds of the video the motor sounds like it is hurtin.
Old Feb 22, 2014 | 05:56 PM
  #123
grey99max's Avatar
LandShark has Cosworth
If you listen to the parts where Travis is giving the engine a little gas in the last part of the video, the engine sounds like it's running normally. I wonder if he means that he was spraying nitrous + fuel after the engine hit the rev limiter ??? Because the rev limiter just cuts 99% of the fuel, and spraying just nitrous would not create any power... the idea of spraying nitrous after rev-cut kinda freaked me out.
At one time, I thought I could spray a large nitrous/fuel shot after the limiter cuts fuel and keep the engine pulling on up. This would take a LARGE combination shot, but if tuned right, it might work. I wonder if that video just showed it happening. ?? Travis??
Old Feb 22, 2014 | 07:58 PM
  #124
If it's possible to tune it for the higher rev without meaning to, then he did it.
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
