How will the stock clutch handle the nitrous?
Old Apr 17, 2009 | 02:36 PM
krazy6's Avatar
Just wondering if the stock clutch will handle a 75 shot. I will jet the nitrous to gain 75whp, not 75 at the crank.
Thanks for the help again guys.
Old Apr 17, 2009 | 04:35 PM
tonedef's Avatar
I think it will be alright for a while.
as long as its not already too worn and u dont spray it every chance u get.
Old Apr 18, 2009 | 10:59 AM
t6378tp's Avatar
Turbo 3.5
stock will hold a 75shot for alittle while
Old Apr 19, 2009 | 04:24 PM
allblackmax96's Avatar
yeah i had about 75k on my stock clutch when i started spraying, its definitely going to put a hurting on it, when i took mine out it was pretty beat, and the flywheel had some hot spots on it (from the initial shock). once i started to get closer to 90k it started to slip more and more. i haven't sprayed on my new clutch yet but i will let you know how it holds up when i do.
Old Apr 20, 2009 | 12:38 AM
one_fast_max's Avatar
the stock clutch should do ok for a little bit as stated....but if you are going to be using slicks and racing alot, your stock clutch is about to get owned dude....haha. start looking into ACT or something
good luck!
Old Apr 20, 2009 | 05:40 PM
krazy6's Avatar
My car only has 26,xxx miles on it, so it should last a little longer than some peoples correct?
Old Apr 23, 2009 | 01:12 PM
T Keck's Avatar
didn't feel like making a new thread but im spraying a 75 shot on my new clutch (oem for a 00-01 with about 3000 miles on it) and im looking into getting slicks, since its new should it hold at least till september (when i have acess to a lift and can do the swap myself). or should i not get slicks
BkGreen97
Apr 2, 2016 05:47 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ef9
Sep 29, 2015 11:29 PM
carlosvq30
Sep 26, 2015 09:44 AM
