Sprayed for the first time, got some questions
Old Nov 3, 2009 | 05:08 PM
  #41
Mad-MAX_SE's Avatar
Still kickin'
Oops. I made a booboo on the diagram, the msd is going to the switched side of the arming switch, not to the battery.
Old Nov 3, 2009 | 07:36 PM
  #42
Mad-MAX_SE's Avatar
Still kickin'
Originally Posted by grey99max
I see something very wrong here ?? - the FP switch is controlling the Gnd (BLK) connection of the MSD RPM switch. This means that the MSD is not powered up until the WOT switch is activated, and that takes a few seconds before it works.
The black wire from the MSD should go directly to a battery ground, and the WOT switch should go to switched battery + , through the FP Switch , to the arming switch +12v connection.
Nice diagram, though....
Ok, after reading your post, the diagram should look like this?
think i might take the time to make this look good at some point for general reference. Going to be doing my own nitrous instal hopefully around christmas
Old Nov 3, 2009 | 07:45 PM
  #43
2002AltimateV6's Avatar
FPSS is only to be used to cut ground. It can't handle any charge. Wire it inbetween the red wire going from the toggle switch to the relay.
Or just look at my earlier post. I have a diagram made out that should work.
Old Nov 3, 2009 | 07:57 PM
  #44
Mad-MAX_SE's Avatar
Still kickin'
Well just because something "cuts ground" (or breaks the circuit) it still has a full charge of the power in the circuit going through it (until it breaks it of course). It's basically a mechanical relay relying on the fuel pressure to keep the internal diaphragm "up" to keep a positive connection through the switch. The original NOs kit had the FPSS on the ground lead of the secondary nitrous solenoid (it ran 2 for regulation of fuel and nitrous pressure). Now that has a lot more load/current going through it than the arming switch.
edit: Here's the diagram
Part of the reason we had the kit wired the way we did, initially, was due to the length of the connectors and wires already present in the kit that just seemed to fit into the car (minus a few odds and ends for the arming switch). Now don't get me wrong, I do agree that having that switch be subjected to those currents would/could lessen the life of the switch. Grant is going to be getting the Dynotune A/F safety cut-off switch here very shortly when he gets a LC1 wideband.
Old Nov 3, 2009 | 07:59 PM
  #45
Originally Posted by Dynotune
NOTE: The switch is a low current switch, running high current devices like solenoids directly through the switch
contacts will destroy the switch and void your warranty.
As per Dynotune's suggestions. Better safe then sorry. Oh well.
http://i2.photobucket.com/albums/y41...2192592A-1.jpg
This should work for your setup.
I believe this should work for when you get the lean/rich shut off switch. Can someone verify?
Old Nov 4, 2009 | 04:40 AM
  #46
t6378tp's Avatar
Turbo 3.5
I have my system wird alittle different but the concept is all the same. I have the niod hard wire directly to the battery and the relay providing ground
And with my progressive nitrous control is does not samething it adds and removes ground but that part does not matter cause a relay will do whatever you tell it
but any of the diagrams will work fine
Old Nov 4, 2009 | 07:15 AM
  #47
grey99max's Avatar
LandShark has Cosworth
That's what I meant - the WOT and FPSS just control the +12 volts going to the relay coil, so no high current there. The MSD should always have power connections and tach connection when the car is running - only use the yellow or grey control wires to run other circuits, like the nitrous solenoid relay.
My dual-stage has a lot of tricks - and the diagrams would be confusing, so I'll skip mine. You should know that energizing the solenoid pair can create a voltage spike that can reset the MSD, which takes a while to reboot. I have large electrolytic capacitors across each solenoid relay to absorb the spike. I use a WOT switch for the first stage and a floor switch for the second stage. There's more, but there's lot of bitter experience in there...
You sure stirred up a lot of interest in nitrous wiring diagrams! never saw so many in one thread.......
Old Nov 6, 2009 | 11:23 AM
  #48
shift_123456R's Avatar
i have mine wired to the horn lol
no WOT switch
not the best setup i know..
Old Nov 6, 2009 | 01:33 PM
  #49
505max94se's Avatar
no WOT switch
Does your horn honk when you spray??
Old Nov 6, 2009 | 11:03 PM
  #50
^^lol no i have a switch to turn the horn on and off
Old Nov 8, 2009 | 02:46 PM
  #51
Sounds like more trouble then it's worth. Better to just get a window switch.
Old Nov 11, 2009 | 02:53 PM
  #52
^if i had the $$$ i would
Old Nov 13, 2009 | 06:28 PM
  #53
I've learned that going cheap on nitrous isn't worth the added risk.
Old Nov 30, 2009 | 12:31 PM
  #54
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
You can get a window switch for 50-60 bucks and have a great amount of added protection. You can't accidentally spray above the rev limiter or too low in RPMs with a window switch (setup properly).
Old Nov 30, 2009 | 12:50 PM
  #55
505max94se's Avatar
I have a DynoTune Two Stage RPM Window Switch / TPS for sale for $60 shipped. Here's a link http://www.dynotunenitrous.com/store...?idproduct=194
max_speed97
Aug 26, 2015 07:46 PM
homewrecker
Aug 24, 2015 08:56 PM
doobadoo
Aug 15, 2015 06:43 PM
jchronis2552
Aug 13, 2015 07:48 AM
ZerotoSixty
Aug 6, 2015 04:34 AM
