Supercharger CELs.
Old Nov 25, 2002 | 04:47 PM
ereet's Avatar
Supercharger CELs.
I got the SC setup a few weeks back (finally), and have been totally loving it. I'm going for emissions in a few days (and hopefully I'll pass), and my CEL came on while cruising around w/o stomping on it. I may have hit up to 3300rpm, which would mean a little bit, but nowhere near WOT. I didn't notice exactly when the CEL came on, but I pulled the codes, and reset it, and they disappeared.
Right Bank Lean
EGR Tempature sensor
I did a search for superchargers running lean codes, and it looks like it's pretty common. As I said, the code didn't come back when I reset it, is this safe to ignore? I'm planning a S-AFC after christmas.
Old Nov 25, 2002 | 05:16 PM
JAY25's Avatar
Re: Supercharger CELs.
I got that code when I installed my SCer. Just reset the ECU and it should not come on. If it does come on expect the 0505 code. Everything is alright and running fine.
Old Dec 5, 2002 | 10:36 PM
iansw's Avatar
I and a few others get a left Bank lean code (0210) every few weeks -
I've had my A/F tuned to within spec, and I still get it now and then.
IanS
Old Dec 5, 2002 | 10:51 PM
BippuBenji's Avatar
Well, I got he 0210 code once one day and I resetted it. The next day it came on again and I resetted it, and it came on again that same day. I resetted it and I poured a bottle of Shogun Import Fuel Injector cleaner from Pep Boys right before I filled up with about 12 gallons of gas when I was on E, and for the past week, I've been CEL free. I remember someone said to use Fuel Injector cleaner because one of the injectors could be clogged causing to run lean, so that's what I did. Hopefully if holds up longer, I guess it did the trick for me. I truly don't want to get new injectors.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Cumalot
Nov 28, 2000 09:38 AM
Mabfnar
Oct 24, 2000 11:17 PM
