Measuring the tightness on the belt
Old Dec 9, 2002 | 10:18 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've read that you shouldn't be able to twist the belt more than a 90 degree angle when gripped between the forefinger and thumb. I've tightened mine such that when I twist it it goes to like a 45 degree angle. Is this too tight?
Old Dec 9, 2002 | 11:08 AM
Chunger's Avatar
My other car is a Hybrid
90 should be enough... I just checked mine yesterday and it was more than that... I've never had a problem with slipping but I only have the 3.6" pulley, though. I wouldn't have it too tight to be on the safe side.
Old Dec 9, 2002 | 10:13 PM
BippuBenji's Avatar
Yea, no more than 90. I have the 3.33" and I made sure mine was at 90. I did hear something about someone saying les than 90 for those who have even smaller pulleys, but I can't guarantee that. Mine seems to be holding up fine (knock on wood).
Old Dec 10, 2002 | 08:39 AM
Stephen Max's Avatar
The smaller the pulley, the less traction area for the belt, and you are driving the blower faster to boot (more power required to turn the blower). So smaller pulleys are going to need more belt tension to keep from slipping.
Old Dec 10, 2002 | 08:43 AM
BlackCat's Avatar
RIP '98 Maxima SE
So with the 3.33" will a 45 degree bend be sufficient or do I have it on too tight? Previously I was judging by the slippage noise. If it was still noisy I'd tighten it a bit more. I have a feeling that I may have overtightened it which lead to the beginnings of bearing failure.
Old Dec 10, 2002 | 09:11 AM
One reference I have on the subject Supercharged mentions tightening till the belt is tight, then tighten some more. Highly unscientific, but the implication is that it is better to be too tight than not tight enough.
AaronL
Nov 15, 2020 11:52 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
RWCreative
Sep 21, 2015 11:01 AM
