Hooked up my EGT and FP..
Old Jan 11, 2003 | 12:41 AM
RBa's Avatar
RBa
Just wanted to know, what numbers are they suppose to read at?
My EGT seems to read at around 700-1000 degrees during idle (after driving for about 10mins) and 12-1400 when accelerating.
The fuel pressure is around 40psi idle, 30 when I gas alittle (vaccum mode). Forgot the number when I boost..
The shop where I had the EGT probe welded used a brasing to weld it.. Dunno if it's a strong weld..
Anyhow, are my numbers off?...
Old Jan 11, 2003 | 09:15 AM
[maxi-overdose]'s Avatar
Re: Hooked up my EGT and FP..
so you are getting 350 - 530 celcius during idle and 760 celcius at peak. that's about right to me. my EGT probe is not welded...it is tapped. I think you are ok.
not sure about FP....I dun have one
Old Jan 11, 2003 | 09:23 PM
GoldenGlory
Old Jan 11, 2003 | 09:27 PM
RBa's Avatar
RBa
Re: Re: Hooked up my EGT and FP..
Originally posted by GoldenGlory
My gauges are ghey.. Don't get autometer!!!!...
And I learned my car is lean and rich at idle and vaccum, lean at wot..
Old Jan 11, 2003 | 09:30 PM
GoldenGlory
Re: Re: Re: Hooked up my EGT and FP..
maybe with ur ghetto installs...sh*t is coming out all wrong
Old Jan 11, 2003 | 09:32 PM
RBa's Avatar
RBa
Another question, how did everyone install your probe? Welded, tapped?
[maxi-overdose],
How did you tap yours? Drilled a hole and screwed in?
My shop had trouble welding it b/c the fitting was brass and my pipe was steal..
And I think it's leaking right now..
Old Jan 11, 2003 | 11:46 PM
Chunger's Avatar
My other car is a Hybrid
My idle temp is about 380C at 650rpm.
Peak EGT today against my friends TT Supra... 700C up to about 105mph... I'm running a little rich, me thinks!
Old Jan 12, 2003 | 12:04 AM
RBa's Avatar
RBa
Re: Re: Re: Re: Hooked up my EGT and FP..
Ghetto? Let's see how many problems you run into.. And I dun mean with just the EGT..
Old Jan 12, 2003 | 01:09 AM
[maxi-overdose],
yup..Kevin drilled a hole and he tapped in the housing for the probe and then he inserted the probe into the housing.
Old Jan 12, 2003 | 11:59 AM
GoldenGlory
Re: Re: Re: Re: Re: Hooked up my EGT and FP..
Old Jan 12, 2003 | 01:17 PM
XXXL Cracker's Avatar
Re: Re: Re: Re: Re: Re: Hooked up my EGT and FP..
Drilled a hoel and welded the fitting into the Y pipe where the two down pipes meet.
N/A readings no juice, no boost
Cruising speed 800F and at WOT around 1050 to 1100F.
D
Old Jan 12, 2003 | 11:49 PM
RBa's Avatar
RBa
Re: Re: Re: Re: Re: Re: Re: Hooked up my EGT and FP..
D
What type of material did you use to weld it??
Do you have a steel or aluminum fitting?
Old Jan 13, 2003 | 05:34 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Re: Re: Re: Re: Re: Re: Re: Hooked up my EGT and FP..
He used KrAzIe Glue
Old Jan 13, 2003 | 05:35 AM
Stephen Max's Avatar
Did you mean to say fuel pressure is 30 psi at idle and goes up to 40 when you give it some gas? I sure hope so ...
Old Jan 13, 2003 | 05:45 AM
RBa's Avatar
RBa
Yeah,, My mistake.. LoL.
I just noticed how awkward that would be. ..
Old Jan 13, 2003 | 09:14 AM
The autometer gauge I bought included a steel "bung" which can be welded into the Y pipe.
It included hardware to clamp the probe to the pipe and the hardware to weld the bung into the pipe.
D
Old Jan 13, 2003 | 10:12 AM
GoldenGlory
maxima297
Sep 24, 2015 01:18 PM
homeyclaus
Sep 3, 2015 06:15 PM
Samedi
Aug 12, 2015 01:54 AM
Mcnabb34
Aug 11, 2015 08:45 PM
MikesChevelle
Aug 9, 2015 11:50 AM
