Hobbs switch mod help
Old 01-18-2003, 01:18 PM
robocop199's Avatar
I just had the S/C kit installed and got the car back last night, it feels amazing, such a difference from N/A. My problem is when I tried the Hobbs switch mod today. What I did was unplug the hose going into the hobbs switch and then plugged the hose. When I took it for a test drive it bogged when the boost kicked in so i pulled over and reconnected the hose. Should I remove the hose that connects to the switch altogether and just plug the 5-way tee? or do you have to plug the switch as well as the hose? any help would be great, thanks
robocop199 is offline
Old 01-18-2003, 05:14 PM
Permanent Maxima.org Resident
Confused's Avatar
remove the hobbs switch all together and wire the inline pump to a relay
Confused is offline
Old 01-18-2003, 06:08 PM
My other car is a Hybrid
Chunger's Avatar
Disconnecting the hose (and plugging it up) should have worked, though.
Chunger is offline
Old 01-18-2003, 06:33 PM
RIP '98 Maxima SE
BlackCat's Avatar
http://forums.maxima.org/showthread....ighlight=hobbs
BlackCat is offline
Old 01-18-2003, 08:20 PM
robocop199's Avatar
I'll be playing around with it tomorrow, hopefully i can figure it out, i hate that lag that i'm getting before the pump kicks in. I bought a walbro pump from the group deal i guess i'll be installing it sooner than i thought, thanks for all the help
sam
gavin68
09-18-2021 12:36 PM
AaronL
08-08-2020 10:31 AM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
lrb6805
09-24-2015 05:03 PM
Quick Reply: Hobbs switch mod help
