Why does my BOV sound better facing passenger side than driverside?
Ok, so I decided to switch out my platinum spark plugs to copper 1-step colder plugs and when I was finishing I decided to face the BOV towards the passengerside when previously it was facing the driverside and it somehow made the BOV sound twice as loud and long with a higher whistle pitch which I like. Why is this? Is it because the air is making a u-turn coming out of the pipe where the driverside method is pretty much letting the air go somewhat in a straight line? Well, I'm pretty much excited about the new sound, but I am a little upset that it made a difference since I've been facing it towards the driverside ever since I installed it 2 month ago. Who else has experienced this? Just thought I would share.
-Ben
-Ben
Re: Why does my BOV sound better facing passenger side than driverside?
-Ben
-Ben
if so how does it sound?? do you get a crisp blow off sound or does your bov start off *** like a WHOOOOOshhhhhhhhhhhhhh..... heheheh that the best i can describe it. i think my BOV sounds a little wierd thats why.
I had the Blitz DD BOV when I initially installed the SC back in late Nov.'02. That one had a swooooosh sound to it, which was ok, but after hearing BrianV's Greddy Type-S BOV I made the switch since it makes more of a whistle sound like the HKS Super-Sequential BOV. I can't really describe the sound it makes but it'll make you switch out the Blitz for one. Here is a link to sound clips of various BOV's. But yea, it sounds much more like a HKS whistle sound than the Blitz swoosh sound.
like yeah mine use to sound kind of like that now iater i have tinkered around with it a bit it like sounds different. i get the WHOOOOOOOOO sound kind of sound like when you blow into a jug and you get that wierd deep WHOOOOOOO sound and then it goes to the wistling. your never does that????
Oh, are you talking about a humming sound before it makes the swoosh sound? I think you have your BOV a little too tight. Both of my BOVs did that when the tightness adjustment bolt was set too tight. I then set my BOVs to its loosest setting without letting the car stall at idle after a rev. With it that loose, I can just rev a little and it'll blow-off air with no humming at all then when it was tight and usually the air would go back into the blower causing it to make that humming sound which is definetely bad for the blower. Is that the humming sound your talking about?
uhhh yeah i believe so. **** its set at like 1 turn from being fully lose. hahaah i have to make it loser.
how many tunrs with the allen wrench did you go. with the sort end of the allen wrench going into the screw.
Hmm, its hard to say. For some reason even at the very loosest setting on my Greddy BOV, it still won't stall, so I screwed it in with like the first 2 threads, so its pretty much at the loosest setting without it falling out. I guess if you have it at its loosest setting and it still kaes that humming sound, I dont know what to tell you.
holly molly hahahahaahahha d@mn i meant 1 full turn after you get a little resistance from the what ever is under neat the screw thingy. hahahaah you have your at the very losest crazy ok ill try that tomorrow morning thanks.
So how loud under driving conditions can I expect the BOV (Blitz DD) to be sinc ei have an auto and the throttle does not completely close between shifts like the manuals?
just curious...
just curious...
just curious...
just curious...
just curious...
just curious...
blitz DD is WEAK sauce.
you can only hear it if you're DRIVING the car, even WITH a 5speed.
greddy type S sounds like wind blowing throw a civ, it whistles.
but at least when at full boost the blow off is cool...
the HOOONNNNNNNNNN noise at start up means you got your bov on a little too tight.
the HOOONNNNNNNN noise is part of my BOV sound. it goes HOOOONNNNNNNShhhhhhhhhhhhhhh
is that bad benblanco said its air going back into the sc and that bad will i damage my blower like that.
but after hearing BrianV's Greddy Type-S BOV I made the switch.
So I tightened it a little where it didn't vent little air at idle and OMG! its superloud! Its sounds too good with it tightened like that but I decided to put it back to the loosest setting, I can't afford a blower repair for messed up bearings. I did get a little humming when it was tightened I put it back to normal, but it is still louder then when it was facing the driverside.
Maxima30
Sep 7, 2015 06:13 PM
