What weight oil are you guys using?
Old Jan 29, 2003 | 06:08 AM
Stephen Max's Avatar
I bought some 15W-50 Mobil 1 for my pending SC installation. I'm influenced by my experience with air-cooled engines (VeeDubs and Harleys), where you want a higher viscosity oil (preferably single grade) due to high heat. Is 15W-50 overkill? Maybe I should go with 10W-30 and an oil cooler?
Old Jan 29, 2003 | 06:10 AM
MardiGrasMax's Avatar
Re: What weight oil are you guys using?
10w30 Redline @ 6k intervals with a 3k filter change.
Old Jan 29, 2003 | 07:40 AM
MAXIN's Avatar
Re: Re: What weight oil are you guys using?
Sorry for the newb question... but you change the filter (at 3k) "without" changing changing the oil? Or am i misunderstanding you.
Old Jan 29, 2003 | 07:45 AM
Re: Re: Re: What weight oil are you guys using?
Yes you can, you will have to add parhaps 1/2qt of make up oil. Recomended by Bill I use the walmart superguard oil filters.
Old Jan 29, 2003 | 07:58 AM
MAXIN's Avatar
Ah I see.. thanks for clearing that up..
Old Jan 29, 2003 | 08:02 AM
BlackCat's Avatar
RIP '98 Maxima SE
I'm using 5W-30 Mobil 1.
Old Jan 29, 2003 | 09:09 AM
Chunger's Avatar
My other car is a Hybrid
0W-30 Mobile 1
Old Jan 29, 2003 | 09:19 AM
robocop199's Avatar
Mobil 1 5W-30
Old Jan 29, 2003 | 10:22 AM
BippuBenji's Avatar
I use Mobil 1 10w-30 and Mobil 1 Filter both changed @ 3K mile intervals which is one expensive oil change, about $33 everytime.
Old Jan 29, 2003 | 12:00 PM
i30krab's Avatar
0W-30 Amsoil Series 2000
Old Jan 29, 2003 | 12:59 PM
20thdriven's Avatar
Mobile 1 10w30, Mobile 1 filter. 3K mile changes.
Old Jan 29, 2003 | 01:18 PM
JAY25's Avatar
I just switched from 5W30 to 10W 30 Mobil 1 with filter except I dont pay tax for the oil since I get it from the Air Force base.
Old Jan 30, 2003 | 09:04 AM
Jer's Avatar
Jer
Syntec 5w50 and Nissan OEM filter changed every 2.5k.
Old Jan 31, 2003 | 05:58 AM
Thanks for all the responses! The consensus seems to be that 30 weight synthetic is the oil of choice. I also found this:
"It is also important to note that, contrary to what many take for
granted, higher viscosity in and of itself does not translate into better
engine protection. Extensive testing has shown the opposite to be in
fact true. As long as a lower-viscosity oil is formulated to resist
evaporation and provide high film strength, this lighter oil will
actually deliver more complete protection to the engine parts, since its
more rapid circulation delivers both better lubrication per se, and far
better cooling characteristics...a critical advantage, given that oil
flow furnishes up to 30% of an engine cooling requirements. Prior to
the introduction of synthetics, however, the problem of evaporation (and
the resultant thickening of the remaining oil) was addressed primarily
by increasing viscosity. In short, don't be concerned with the
relatively lower viscosity ratings of some synthetics. Syn lubes are a
whole new ball game."
reference
Based on this I took the 15W-50 back and exchanged it for 10W-30.
Old Jan 31, 2003 | 06:08 AM
hlh0501's Avatar
same here, sometimes bosch filters depends where i am.
Old Jan 31, 2003 | 08:01 AM
Jer's Avatar
Jer
Looks like my 5w50 has been condemned
Then again, I've never had any issues with the stuff, and although it's not a "pure" synthetic I'll keep on using it......... unless someone here has lost a motor to it lol.
reference
Old Jan 31, 2003 | 11:15 AM
funnylittlman's Avatar
I switched to Mobil 1 5w30 before the s/c install, ended up not installing the s/c and now just run it "FOR BECAUSE"
Oh at 5K intervals. I just changed my oil wed, and after 5k miles it still looked somewhat clean
Old Jan 31, 2003 | 11:16 AM
Jeff92se's Avatar
I'm needing a caw
Amsoil. Superior film strength
Old Jan 31, 2003 | 02:02 PM
Jer's Avatar
Jer
Amen to amsoil, however just as it's "bad" to switch from reg. to synthetic after too much mileage, I feel as if I would take a risk switching from "cheapo" syntec to amsoil.. so I'm staying with the cheapo stuff lol
Old Jan 31, 2003 | 02:09 PM
Jeff92se's Avatar
I'm needing a caw
Jer, it's not "bad" to do either.
Old Jan 31, 2003 | 07:28 PM
sleeper's Avatar
oil weight
castrol syntec, 5w-30.
Old Feb 1, 2003 | 11:29 PM
Jer's Avatar
Jer
Well... from what I've seen it's not good to switch to synth after too much usage of regular oil.... esp. in light of all the deposits that accumulate over time..
Old Feb 2, 2003 | 01:21 AM
Jeff92se's Avatar
I'm needing a caw
Put it this way, if someone's engine is sooo bad that the gunk is stopping leaks, your engine is probably past the point where synthetics might do something of benefit IMHO.
You can't really say it's bad to switch. What is the cutoff? 10k, 20k, 30k, 70k 100k? What if someone changed their oil regularly for 75k and the engine is spotless? But another didn't change their much at all for 45k and their engine looked like black death?
Cotozic
Jun 28, 2017 08:01 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
4 door GT-R
Aug 22, 2015 07:50 AM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
