CAI on a SC
CAI on a SC
OK I am putting in my SC and doing the CAI mod at the sametime. I went to Home Depot to get this ProFlex coupling (brand Ferno) and could not find it. But I found a rubber hose that fits over the 3 1/2" pipe and on to the SC with a metal houseing and 2 SS hose clamps around it.
Is this what I am looking for?
Has anyone done this that can tell me what it looks like?
How hot the SC get? Will it melt the rubber?
Thanks in advanced
Thanks in advanced
Re: CAI on a SC
Thanks in advanced
Thanks in advanced
If you want those silicone hoses check out your local speed shop. The one I go to sells them by the inch.
I used stillen's 90 degree elbow (black) and faced it nearly straight down to the ground (5th gen). From there I connected black flex hose from home depot (looks like an enlarged version of the flex section on flexible straws), then connected the MAF, then the K&N sitting right behind the passenger side fog.
Using the 90 degree elbow, heat is not an issue. It should be fine with the hose you bought.
I forgot... On 5th gen SC's does the recirculation hose return the air before or after the MAF sensor??? Since I removed my BOV the car boggs a little at low rpms, I made mine return air before the MAF.
I went to a boat supply store and bought a section of 3.5" inside diameter wet exhaust hose. I ordered a 3.5" mandrel bent aluminized steel exhaust pipe section. I fit all this together and with a K&N filter rated for the CFM I was flowing.
You can use this wep page to calculate the needed CFM. http://www.smokemup.com/auto_math/airflow.php Our 3.0L engine is 183 CI. Its a V6 of course and our redline is 6500. Leave VE and air temp set at what they are. As an example, at 10psi you need a filter rated for ~491CFM, add 20% and your filter should be ~589CFM. Call up K&N and give them that figure and tell them the dimensions you need with a 3.5" inlet and they can give you the part number and just order that filter from Summit or Jegs where its cheeper.
If your gonna do it do it right
I have done the mandrel bent 3 1/2 pipie and this part that I got at Home Depot fits ofer the piupe and the SC perfrectly, maintaing the inside diameter the same size as the SC so there is no restriction.
The filter that I got is a K&N RU-1784 I don't know the CFM rating on the filter.
Can you tell MardiGrasMax?
Re: CAI on a SC
Thanks in advanced
Thanks in advanced
http://maxima.cardomain.com/member_p...=259227&page=2
Latin, the Proflex coupling is a 3 inch long by 3 inch diameter metal coupler (joins two sections of pipe or hose). You don't need it for the install, but it can be used.
MardiGras, the stock Stillen elbow goes from the 3.5" inlet on the SC down to a 2.5" pipe (the intake pipe). I think using a 3.5" hose is best, but using a 2.5" is the same as stock, except you get cold air with the CAI.
I searched everywhere for the intake hose and finally found it at O'Reilly's auto parts (used to be Hi-Lo). They actually have 3.25-3.5" intake hose (black plastic covering a metal coil) that can be adapted for the CAI. It was $10.
Originally posted by MardiGrasMax
The part you are talking about is on the pressure side of the blower on a 4th gen set up. If you restrict the 3.5" inlet with a 2.5" tube you will loose some induction flow and the cold air effect will be negated from a loss of boost.
Maxima_Joe
Nov 25, 2015 08:19 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
