Exhaust wrap, how does it continue to smell?
Well just put on the wrapping on last night and after starting the car and driving it 2miles, It started to REALL smell inside the car as the wrap got hot and I guess starting heating up and burning some stuff.
But after driving here to UNC Chappel Hill (250mile drive) it still smells under the hood.
I just want to rule out what it is? I want to make sure it aint something else burning/smelling. Mainly due to the fact it really stinks.
Also I got some wrap left over. Currently I wrapped the whole downpipe past the tranny pan. And wrapped part of the Ypipe, basically wrapped the pipe from the front header to the wastegate and small section from the wastegate to the turbo.
Should I wrap the other half of the Ypipe as well?
Man I need a lift.
Dixit
Man I need a lift.
Dixit
I dealt with the same issue on teh flex section of my y-pipe but I could not smell it inside the car...only when I was working on the middle area around the back of the engine.
only thing is it got wet a few times and dried out so often, I guess it just did not make as much odor after a while...under hood I can imagine it would smell for a while unless you soak and dry it a few times before re-installing.
Originally posted by Y2KevSE
The smell should go away after 5 semi-long trips. Afterwards, it will smell on occasion. Does your smell like cookies? Mine did.
Dixit
Originally posted by BigDogJonx
Dont smell like cookies here, more like burnt crap. But what about my question on the extra wrap left? Should I continue to wrap the entire Ypipe? or go further down to the cat from the downpipe?
Dixit
Dixit
I use Thermo-Tec... what do you guys use?
It's really up to you, Dixit.
I use the same wrap, it and smells nasty after sprinted run. I guess I will wrap the rest of the Y then.
Hmmmmmm........ the smell from my car is sort of sweet and pleasing. Not anywhere near what crap smells like.
God no not on this one. It definetely smells like burnt cloth.
Kev, quick question, what was that site that LatinMax and a few others bought gauges from? something like groupo.com or something. I cant remember, they sell Greddy, Apexi, HKS gauges.
I want to get these brands, but keep running into issues cause I dont want a bar reading, I want PSI reading.
Dixit
Yes, sweet and pleasing... sort of makes you hungry after smelling it.
www.gruppe-s.com
www.gruppe-s.com
www.gruppe-s.com
www.gruppe-s.com
sounds yummy to me
time to bake some chocolate chip cookies tonight
www.gruppe-s.com
www.gruppe-s.com
Originally posted by LatinMax
Thats them. Just remember that sometime they are a little slow. I ordered and it took 4-5 weeks to get them. They were nice and kept me up to date but it still took a while.
I got the Greddy Boost, Fuel preasure and EGT.
I take it you bought all of them 52mm electric ones?
So you your boost and fuel pressure reading in metric? I dont want that, I want boost in psi and fuel pressure in PSI.
DC_Juggernaut
Sep 28, 2015 04:07 PM
