View Poll Results: Which kit is better and why?
Nigel's
32
47.06%
Hal's
36
52.94%
Voters: 68. You may not vote on this poll
Which turbo "kit" is better?
Old Apr 11, 2003 | 11:18 PM
  #121
Deac's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: WHAT?!?!
Originally posted by Y2KevSE
Should done it my way.
I wish we were getting a free gauge.
I think Nig will splurge a bit and get us some free gauges. After all... what is it? Only 3 guys?!?! C'mon Nig!!!
Deac
Old Apr 12, 2003 | 06:04 AM
  #122
Sprint's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: WHAT?!?!
Deac
3 guys? you not counting yourself in that?
Old Apr 12, 2003 | 06:15 AM
  #123
JAY25's Avatar
Deac
you guys about to get some free gauges?
can I get one too?
Old Apr 12, 2003 | 06:59 AM
  #124
Bags's Avatar
VG Ridah's Biatch Hoe
Nigel, I was NOT knocking you guys for qouting books, I was saying that as a compliment.
And yeah your correct on the heat issue. I just was saying if you BOTH would let the petty little dumb **** go, yall both could help MOST of us.
But I will stop there
Old Apr 13, 2003 | 10:41 AM
  #125
redmaxpa007's Avatar
i SeE what you did therE
Old Apr 13, 2003 | 11:57 AM
  #126
nadir_s's Avatar
vicodin ... gift of life
Unbiased analysis...
PFI
Cons
- need to cut metal bumper support
- need to drill holes into frame
- non-mandrel bend piping if you don't upgrade (pressure bends)
- tap oil return to valvecover
- may be missing parts
- bad instructions (I didn't even use the instructions) might be better now
- piping may be off
Pros
- T-bolt clamps
- engine bay looks clean after install
- "bolt-on" kit
HLH
Cons
- lose fog lights
- extra piping around turbo to TB
- piping hangs a bit low
- removal of stock fans for smaller fans
- exhaust piping runs next to the radiator (the left half)
- needs custom installation
- 2.5" down-pipe leading to 3" cat-back
- tap lower oil pan to return oil
- no flex section
Pros
- free install
- no need to cut bumper
- 3" cat-back included
- boost and a/f gauge included (a/f gauge is useless unless you like light shows)
- turbo timer included
just curious to know what u mean by free install.
Old Apr 13, 2003 | 03:30 PM
  #127
carnal_c30's Avatar
Former Sponsor
if you drive to the shop in kentucky you get free install
Old Apr 14, 2003 | 06:54 AM
  #128
Aaron's Avatar
Langley AFB Sux
Wow.............
Guess I'll just up the shot then. Dont have the time or cash to deal with turbo issues. (yes i know things like this are'nt hassle free).....Specially since this is our only car
Old Apr 14, 2003 | 07:59 AM
  #129
Y2KevSE's Avatar
Rice Boy in Denial =)
Free install can be a con or pro... but almost everyone will look at it as pro since cost has been included in the kit.
It's a con because if you run into issues and you live far away... you're somewhat screwed.
Old Apr 14, 2003 | 08:41 AM
  #130
johnvt1111's Avatar
disagree, that's why you plan it out so if problems do arise you find ways around them....(rent or borrow a car for the time being in the shop). With all the headaches it saves with installing yourself, free install is definately worth it and saves$$$$$$$$
Old Apr 14, 2003 | 09:34 AM
  #131
Y2KevSE's Avatar
Not as easy as you say.
[edit]
Rent a car? That's money out from your pockets. How long will it take to fix a problem? You don't know...... two, three days.... maybe more. Another important question: Are you always going to drive to Kentucky if you live in say, Maryland?
You gain experience from installing the kit. You also can probably diagnose a problem easier since you will be somewhat familiar with it.
Free install is good if done professionally.
Old Apr 14, 2003 | 09:37 AM
  #132
nadir_s's Avatar
kev drove all the way to kentucky ?
Old Apr 14, 2003 | 09:42 AM
  #133
Y2KevSE's Avatar
I would not let anyone I do not know work on my car.
Hal's kit... you need to drive to Kentucky. PFI/Nigel's kit... you can install it in your own garage if you get the right parts.
Old Apr 14, 2003 | 09:43 AM
  #134
nadir_s's Avatar
ooohh i get it now
Old Apr 14, 2003 | 02:07 PM
  #135
carnal_c30's Avatar
Former Sponsor
thats why I'll get a job at the local jiffy lube and demod your car while you let me do an oil change
Old Apr 14, 2003 | 05:28 PM
  #136
Y2KevSE's Avatar
thats why I'll get a job at the local jiffy lube and demod your car while you let me do an oil change :-)
So when are you coming up again? SoCal and Hal must be corrupting you.
Old Apr 14, 2003 | 05:31 PM
  #137
johnvt1111's Avatar
Kev have you hit the track yet with your new setup, or any nice "closed course" runs? Very interested in what you've done to the car like to know how things are with it since you have so many goodies
john
Old Apr 14, 2003 | 05:44 PM
  #138
Y2KevSE's Avatar
john
YGM.
Old Apr 14, 2003 | 06:41 PM
  #139
Bags's Avatar
YGM.
CARE to share again???
Old Apr 14, 2003 | 06:47 PM
  #140
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
YGM.
Keep on trying RICE boy.
Old Apr 14, 2003 | 10:13 PM
  #141
Y2KevSE's Avatar
John can post my response if he wishes... nothing important to move along.
Old Apr 15, 2003 | 01:07 PM
  #142
max95q's Avatar
Plus renting a car isnt as easy if your state has an age limit that you havent met yet. 25 in Texas to rent a car. Then what?
Old Apr 15, 2003 | 01:12 PM
  #143
Cumalittle
negative partner...21 is the age...
Old Apr 15, 2003 | 02:23 PM
  #144
max95q's Avatar
nuh uh for real!!! Dang Im 21 did this change recently?
Old Apr 15, 2003 | 02:28 PM
  #145
johnvt1111's Avatar
well either way, if you do it yourself or in the shop, I'm saying you have to be prepared to find other ways of transportation since it definately isn't a one day job!
Old Apr 15, 2003 | 04:55 PM
  #146
Cumalittle
i dunnoe...but when i was in an accident...enterprise just asked me if i was atleast 21 and insured...this is in houston...
Old Apr 19, 2003 | 02:11 AM
  #147
passat8mycash's Avatar
dont waste uer money on nigels kit, waste it on hals, cuz hals is way better!!!
Old Apr 19, 2003 | 08:17 AM
  #148
dmontzsta
Old Apr 19, 2003 | 01:03 PM
  #149
RS Motorsports's Avatar
Do you even know what your talking about, i would rather have a kit that doesn't give me any problems than one that was obviously not planned very well. Pfi the company designed the kit is a very well known performance shop in the import world, Their kit was designed alot better than Hals, im sorry but the turbo placment with hals is way to close to the engine and hoses, which causes melting, baggs has already seen this, with the auto kit the piping runs under the tranny pan loosing clearance plus the work that the shop does to install it is crap. I would rather have a company that desings kits for many cars and proven that they work install a turbo on my car, i would rather deal with small little issues than **** melting and breaking on me. Im not trying to bash you in any way hal but i just think that their could have been a little more planning involved with your kit. Just for the record i was very temtped to go with hals until i talked to the guys at pfi and they showed me what was wrong with it, and to anyone that has issues with pfi's work i have had no problems with the install job, it is very clean and nothing has failed on my car yet.
Ryan
Old Apr 19, 2003 | 03:21 PM
  #150
Sprint's Avatar
25 in CT
Old Apr 19, 2003 | 04:55 PM
  #151
johnvt1111's Avatar
Ryan
what makes you think Hal hasn't thought out his turbo very well, it's basically the same price, comes with more, and get more h/p out of it.......so saying something isn't thought out isn't right, you guys are knocking hal, i'm pretty neutral, it's what you make out of it, how you tune it, and other goodies you add.........i think this thread is kinda out of order with people taking sides
Old Apr 19, 2003 | 05:20 PM
  #152
Get more hp out of hals kit?, i havn't seen one dyno except for bigdogjonx and it was not higher than any of pfi's kit #'s. yes it may come with more but at what price, having hoses metled pipes bent boost pipes coming off hoses that aren't the right size. I just think that it could have been thought out a bit more and the people that are installing it doing a more proffessional job. Now im not knocking hal at all, its great that he came out with the kit to give more options to us, i just feel that it could have been planned a little better.
Old Apr 19, 2003 | 05:25 PM
  #153
joaquink's Avatar
¿Hablas Español?
[B]
If you think it's any different with a PFI kit for a manual 4th gen, you're deluding yourself. I'll honor the gentleman's agreement to not post pics but I lost a fair amount of ground clearance with a PFI 5spd system as well.
I can only comment that I installed the PFI system myself because, hey, why not, "It's just a weekend thing." Not sure if Nigel is reading but I'd still like to know whether he's basing this thought on his own, solo, and actual installation of a 4th gen kit or if it's based on his understanding of the kit. If he did do it, did he do it at his own home, with his own tools, and the provided instructions?
I agree with you there, but there is also a breaking point on the "small issues" when you pay dammned close to $5,000 for a "bolt-on" and "weekend thing" kit.
I'm not trying to bash you in any way hal but i just think that their could have been a little more planning involved with your kit. Just for the record i was very temtped to go with hals until i talked to the guys at pfi and they showed me what was wrong with it, and to anyone that has issues with pfi's work i have had no problems with the install job, it is very clean and nothing has failed on my car yet.
Ryan
So it sounds like you had PFI do the install. How long did they, the shop that designed and custom fit this sytem, have your car?
Did you have to take it back after the initial return to you? If so, for how long and/or to have what issues addressed? Did you ever have to reschedule your install while they waited for the right parts to arrive? Did you tap your valve cover or the oil pan? Did you look to see whether they forced a 1/8 standard pipe thread into the 1/8" BSP fittings?
What all did you have them install? Maybe part of the deal with a PFI kit should be that you take your car to Ft. Collins for installation by the experts at PFI.
Old Apr 19, 2003 | 06:20 PM
  #154
What all did you have them install? Maybe part of the deal with a PFI kit should be that you take your car to Ft. Collins for installation by the experts at PFI. [/B]
Yes i had pfi do the installation of the entire kit, They had my car for 5 weeks only b/c it was the first automatic they had done and they where trying a bunch of different setups for the piping (alot less room to work with due to the size of the auto trasmission). I have talked to them about install now on the kits and they told me that a week as long as all the parts are in stock, and it will be alot easier now that there exhaust guy is moving into a shop a couple buildings down. also i tapped the valve cover on mine and havn't had any issues.
Ryan
Old Apr 19, 2003 | 06:48 PM
  #155
joaquink's Avatar
¿Hablas Español?
Fair enough to make the modifications and get piping from their source. From what you're saying it sounds as if they don't make/bend the piping themselves to that's understood.
So, the PROFESSIONALS WHO DESIGNED THE KIT FROM THE GROUND UP SAY IT WILL TAKE AT LEAST 1 WEEK (IF (that's a really big if based on my experience) ALL PARTS ARE IN STOCK.)
Ryan
Same here and no issues either other than the tapping itself. What size line did they run for you and what size fitting did they use? I can get you a non-tapered, non garden-hose-repair-kit barb in a 5/8" or 3/4" fitting for the valve cover if you'd like. Just let me know whether they drilled and tapped a 1/2" or 5/8" NPT hole there and the i.d. of the hose you're running if you want to change it. Mine was tapered 1/2" brass at the valve cover and a 3/4" steel nipple at the turbo.
Old Sep 25, 2003 | 07:47 PM
  #156
|Bijan|'s Avatar
UCF Lexus
Ssr Engineering
Old Sep 25, 2003 | 08:11 PM
  #157
Shadow's Avatar
It doesn't exist yet though right?
Originally Posted by bijan gxe
Ssr Engineering
Old Oct 12, 2003 | 10:55 PM
  #158
Y2KevSE's Avatar
This thread is acting weird... I'm going to lock it.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
