Wish me luck (project)
Old May 11, 2003 | 01:12 PM
Chunger's Avatar
My other car is a Hybrid
Finally gonna do this today:
So I can do this later:
Old May 11, 2003 | 01:27 PM
JAY25's Avatar
3.??? or 2.?? what size pulley are you putting on there my fwiend? You ready to own someone on the street?
take your time and good luck
Old May 11, 2003 | 01:38 PM
Confused's Avatar
Permanent Maxima.org Resident
why do you need a new belt to put in a new radiator?
j/k... good luck chung..
Old May 11, 2003 | 01:56 PM
Jer's Avatar
Jer
Enjoy
Old May 11, 2003 | 03:22 PM
Chunger's Avatar
Just a 3.125".... not as brave as you folks...
Hopefully I won't need a new (larger) radiator if too much air is impeded with the FMIC.
After taking some stuff out, i discovered I have to rethink my IC piping
Some good news... my steel ASP tensioner pulley looks like it's in great condition.
Old May 11, 2003 | 03:23 PM
20thdriven's Avatar
what are the IC specs (dimensions, flow rate)??
good luck keep us posted.
Old May 11, 2003 | 03:57 PM
Chunger's Avatar
20 X 10.5" Spearco good up to 930cfm and 650hp.
Old May 11, 2003 | 04:59 PM
MardiGrasMax's Avatar
cool!
Old May 11, 2003 | 05:10 PM
20thdriven's Avatar
an added extra
don't know how much you go to the dragstrip but for all you IC folks you probably know about NX's N-tercooler. to save about $200, check this site out
intercoolertechniques.com
an extra 65whp on a supra (I know turbos create more heat but still)
Old May 11, 2003 | 10:16 PM
[maxi-overdose]'s Avatar
keep us updated~
Old May 11, 2003 | 10:33 PM
Chunger's Avatar
This was a sign to stop for the day...
The 8mm Allens came out pretty easy, it's the 7/32" ones that are tough... the first one broke my socket... gonna have to get "evil" on it tomorrow.
FYI, the "new" polymer idler pulley looked just fine as well and the fitment of the steel ASP idler is the same.
More pics later.
Old May 11, 2003 | 10:42 PM
Chunger's Avatar
new steel ASP idler on left, used "new plastic" one on right:
Haven't seen this much space here for a while
Old May 11, 2003 | 10:55 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
What are you going to do with that big radiator?
Old May 12, 2003 | 08:56 AM
Chunger's Avatar
I'm gonna "be cool"...
Old May 12, 2003 | 11:56 PM
Chunger's Avatar
Argh... what a day.
Removing the four 7/32" allen heads from the assembly was a major pain. Destroyed 2 Snap-On allen sockets today and had to use a propane torch and cheater bar.
Grinding the S/C bracket center post, done.
Reassembly of the S/C and bracket with new '705 belt, done.
Installed new Power Steering belt, done. <<Major Pain>>
Resealed drain back plate, done.
Just waiting on the new lower radiator hose then I can change the coolant and put her back together.
I'll get there sooner or (looks like) later...
Old May 13, 2003 | 05:23 AM
Confused's Avatar
and more scoping out of the intercooler?
Old May 13, 2003 | 08:27 AM
Chunger's Avatar
Brett - found out that i can't make a 90 deg bend straight down (there is a vertical part of the frame there) so I will try two 90 deg bends to run it down by the radiator. It's very tight there, especially since I will be using 2.75" piping.
That project is a while down the road... I just wanna get my car up and running now... maybe a baseline w/o FMIC on a dyno, too.
Old May 13, 2003 | 09:13 AM
JAY25's Avatar
he may be playing catch up, I am in the same boat should I go with the cool look and spray some of that cold ice air out of the blue bottle onto it and see more torque just confused one what I want to do next to bring my torque up some. In any case great idea
Old May 13, 2003 | 10:35 AM
Y2KevSE's Avatar
Go with rice juice... but make sure your injectors can give you adequate fuel.
Old May 13, 2003 | 06:40 PM
JAY25's Avatar
I spoke to the man today Mardigrasmax, he told me how to do it. I am running very rich between 3-5100RPMs I know that for a fact, I can richen the mixture on the safc +10 from 3-5K spray it and see if it will utilize the fuel for a 25shot and move on to a 30 shot and I will be good to gain what I lost midrange like you said about the VI and hopefully I will gain @ least enough to get me to plus 300Lbs of Torque.
Old May 17, 2003 | 06:21 PM
Chunger's Avatar
She's Alive!!!
Still using the 6:1 disc... a full boost run in 2nd and 3rd netted no detected knock on the J&S and 700C peak EGTs... hmmm.
I have some strange metallic like sound that comes and goes from either the new steel idler pulley or the S/C... still hunting that down.
Old May 17, 2003 | 11:46 PM
Confused's Avatar
thank you doctor... thank you
Originally posted by Chunger
She's Alive!!!
Still using the 6:1 disc... a full boost run in 2nd and 3rd netted no detected knock on the J&amp;S and 700C peak EGTs... hmmm.
Old May 18, 2003 | 12:25 AM
Chunger's Avatar
Here's a better picture of the areas for grinding on the V2 bracket...
I went a little "evil" on the center post...
The lower part shows the cut lines but I hadn't popped off the portion that needs to be removed yet...
and the reason it needs to be ground down...
Old May 18, 2003 | 11:56 AM
Y2KevSE's Avatar
Now get that IC in.
Old May 18, 2003 | 12:31 PM
20thdriven's Avatar
I know some SC max's are intercooled...but does anyone have actual before/after dyno or track numbers??? Post them please if you do. Or post the differences you felt after the install. if not, my setup should be done in a couple weeks so I'll post then.
Chunger, like kev said...get that thing in!
Old May 18, 2003 | 01:16 PM
Chunger's Avatar
Darn... easy for you guys to say
Old May 18, 2003 | 02:50 PM
JAY25's Avatar
good question anyone that is SCed and that is intercooled have any track numbers or Dyno numbers?
aw11power
Oct 10, 2021 04:57 AM
howardis
Dec 11, 2019 06:10 PM
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
RealityCheck
Oct 2, 2015 06:34 PM
