pros and cons of a SC
Old 10-16-2003, 11:24 AM
Future Camaro SS owner
MyownNismo's Avatar
Can you guys give me some pros and cons of a SC. Here's my situation I really don't want to get rid of my y-pipe. I don't really want extreme horsepower. Stealin says there SC make 95 HP so I would be at 280HP which would be fine for me. I plan on swapping trannies (2k1 20th VLSD).
To me it sounds like the most problem people have is slipping belts, What could I do to prevent that from happening.
MyownNismo is offline
Old 10-16-2003, 11:44 AM
ereet's Avatar
I don't really understand your post. Y-pipes work fine with the Stillen kit, stock or aftermarket. An aftermarket one will give a LOT more gain though.
Stillens HP estimates are at the crank, so if the 2000-2001 have 220hp rated by nissan, you'd have 315, which with a 18% loss, equates to ~260ish fwhp. 260 still seems a bit high to me with a stock exhaust and 3.6" pulley, but you can always swap a smaller pulley in if you're after more horsepower. Belt slippage is all dependant on what type of belt you use and how tight you keep it. If it's slipping, it's most likely not tight enough.
The only other problem is the V2 tends to shred belts a little more often.
ereet is offline
Old 10-16-2003, 11:57 AM
MyownNismo's Avatar
I forgot to delete the part of the y-pipe since I was going to do pros and cons of a sc and turbo but decided that I will probably just go SC.
I will most likely run stock pulley.
Old 10-16-2003, 12:18 PM
RIP '98 Maxima SE
BlackCat's Avatar
Belt problems will always show up once in a while so be prepared. I consider it a part of owning an SC.
BlackCat is offline
Old 10-16-2003, 12:29 PM
[maxi-overdose]'s Avatar
stock pulley + stock ypipe = still cant smoke a CLS.
jer got a 0.7s on 1/4 with aftermarket ypipe and SC.
[maxi-overdose] is offline
Old 10-16-2003, 01:20 PM
RIP '98 Maxima SE
BlackCat's Avatar
We'll see how long that will last!
BlackCat is offline
Old 10-16-2003, 01:41 PM
Stephen Max's Avatar
That is a con I was going mention. Lust for more power.
Stephen Max is offline
Old 10-17-2003, 01:40 AM
MyownNismo's Avatar
Lust for more power could happen. I don't have stock Y-pipe I have an Cattman. I guess I would just have to keep a SC emergency kit which would include new belts and tools needed to handle a breakdown on the road. What about fuel management how much would I have to do to keep that running in proper order. Like upgrade fuel pump, FPR, how about a SAFC II. What about Stand Alone fuel Mangement.
Old 10-17-2003, 05:42 AM
JAY25's Avatar
You ll have belt problems if the plate is not properly aligned. Missing bolts or stand off bolts to align the plate may contribute to shredding belts. I owned a V2. It was a very reliable set up. I never had one problem.
JAY25 is offline
Old 10-17-2003, 07:58 AM
RIP '98 Maxima SE
BlackCat's Avatar
If you do a search on my V2 experience you'll see that belt problems only came up 3 times in my 3 years of ownership.
BlackCat is offline
Old 10-17-2003, 01:00 PM
MyownNismo's Avatar
Would you say to get it installed professionally or could it be a DIY job.
What about fuel mangement what is key to keeping car running.
Old 10-17-2003, 01:13 PM
RIP '98 Maxima SE
BlackCat's Avatar
I originally had mine installed by a speed shop that installed Vortechs on Mustangs. With the org's help I was able to tinker around and learn how to tear down and reinstall the blower.
BlackCat is offline
Old 10-18-2003, 01:39 AM
MyownNismo's Avatar
I want to add a intercooler to it but will have to do some custom piping.
I figure I will run the next pulley from stock and from reading other threads it would be 8PSI. Adding a BOV also helps. With running the second pulley would I need to add a better fuel pump. reading that injectors would be fine. Any help with fuel management is needed to clarify and run the SC safely. Thanks for all your help.
Old 10-18-2003, 07:42 AM
Nazgul350r's Avatar
just watching
Nazgul350r is offline
Old 10-18-2003, 03:20 PM
MyownNismo's Avatar
Originally Posted by Nazgul350r
just watching
Well after awhile I decieded not to get a SC right now. I know I would like to go faster and if I came into some serious money like winning some money I would do it but the money's not there so I am holding off on it thanks for all your help.
Old 10-18-2003, 03:59 PM
GoldenGlory
i highly agree with jay here. jeff installed my blower back in feb and not one single problem. my belt is still fine... dry rotted and crack it stands now...thats because of the abuse that belt is goin thru. and its been 10,000 miles almost since the install.
everyone on here who has had problems with the belts coming off or tearing off are all due to the install being done incorrectly.....
jay i got the warpspeed straight pipe
this is me now...
holy nutz... what a difference
Old 10-18-2003, 04:12 PM
JAY25's Avatar
this is me now...
all that pressured air in has to flow out as fast as possible. Makes sense now
JAY25 is offline
Old 10-18-2003, 08:42 PM
GoldenGlory
you dont come on AIM anymore heh ?
yea bro,since the install of the straight pipe my car is a complete different beast now.
cant wait to go WOT...maybe when this weather settles..
Old 10-19-2003, 12:01 PM
upgrade the fuel pump to walbro high pressure and get yourself a fuel pressure gauge. (electric one)
FMU ratio - depends on what pulley are u running. anything below 3.33, use an 8:1. adjustable FMU is recommended if you want to fine tune the car.
FPR - if your peak fuel pressure is high, use adjustable FPR to lower base fuel pressure so you will have more room to boost your fuel.
stand along management - you will need larger injectors to do this.....we will soon find out if a larger injector is available for VQ30DE-k
have fun ~
Old 10-19-2003, 01:59 PM
MyownNismo's Avatar
have fun ~
Thanks for clearing up the fuel issue but right now I am holding off till I come into some extra money.
Old 10-19-2003, 10:54 PM
JET Speed Lab
ToYLeT902's Avatar
Pro: My car is fast
Con: its still a maxima
ToYLeT902 is offline
Old 10-20-2003, 12:44 AM
MyownNismo's Avatar
Originally Posted by ToYLeT902
Pro: My car is fast
Yes there is now hope of getting my SC I am getting a second job at an airline company where I will work two days for $10.00. Good news is if I get hired I get unlimited plane rides so I can go anywhere I want for free.
Old 10-20-2003, 12:47 AM
JET Speed Lab
ToYLeT902's Avatar
Hook me up with some tickets, say im a family member
Old 10-20-2003, 01:20 AM
MyownNismo's Avatar
Only way that would workis if we where on the same flight.
Old 10-20-2003, 01:21 AM
JET Speed Lab
ToYLeT902's Avatar
So what are you doing next month?
Old 10-20-2003, 01:46 AM
GoldenGlory
there u go..come pick up ur VB MOD!!!
Old 10-20-2003, 04:02 AM
MyownNismo's Avatar
Don't know yet.
VB Mod if I get this job the 5spd conv also comes back into play.
Old 10-20-2003, 03:36 PM
A couple of Blaxxx's? Lawls.
slimer's Avatar
definitely vb all the way!
slimer is offline
Old 10-21-2003, 12:55 AM
MyownNismo's Avatar
If I get the job it opens up the possiblities of getting the SC and 5spd Conv. If I don't get the job I plan to get the VB. Guess we'll wait and see.
Old 10-21-2003, 02:10 AM
GoldenGlory
good luck man
Old 10-22-2003, 12:33 AM
USDM-A32's Avatar
If you decide to get the SC, install it with at least the 3.33 pulley, it'll rid you of headaches later of not "feeling" the boost. May I also suggest staying away from VB mods and just getting the 5-spd conversion before boosting, the auto tranny will not hold the boost and you WILL have to get a rebuild within weeks. The VB is only going to make the 1-2 gear shift faster, but it will not live up to shifting fast enough for the SC after awhile.
USDM-A32 is offline
Old 10-23-2003, 01:56 PM
ereet's Avatar
I agree. You may want to hire USDM-A32 the anti-auto advocate on your 5speed upgrade too, since he can have it done for a "few" hundred dollars.
ereet is offline
Old 10-24-2003, 08:49 PM
MyownNismo's Avatar
I found a place here in MN that will install for $600.00. But I am going to put some of the easy stuff in.
Old 10-27-2003, 03:51 PM
smokedford's Avatar
I've been blown for over a year now.... The only problems I ran into were during the install... (rushing it) and the small oil hose that requires hands of a 10 year old to get to. I have gone over 16,000 miles with no problems. (minus the tranny)
I just might be the only one that has blown up a manual tranny with the SC.
If you have time and patients, the install is not that bad. But if you find someone to install it cheap, go for it. The stress and the weak instruction from Stilen will make you kick your dog and yell at your kids.
Disclaimer:
Smokedford doesnot endorse or promote violence towards animals, spouces, or objects of value.
smokedford is offline
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
spencerwh1
06-30-2016 05:44 AM
ivorton23
09-28-2015 09:08 PM
Spartan1310
09-28-2015 08:03 AM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: pros and cons of a SC
