SC oil return line is a nissan part.
Old Oct 27, 2003 | 01:46 AM
jdmmax's Avatar
i remember reading a few post about how the oil return line was a nissan part. I do not remember reading if anybody figured out what part it was. i think i figured out which nissan part it was.
top one is the stock crank case ventallation hose on the 4th gen maxima.
bottom is the oil return line that i ordered from stillen a few weeks ago.
i stumble across a box full of stock parts while cleaning my garage this weekend. i matched the two part side by side and this is what i found.
the oil return line cost me $27 dollars i believe retail on the hose is closer to $35 or so. something like this sould cost around $12 dollars at nissan. maybe even less.
what do you guys think???
sorry if this is a repost.
Old Oct 27, 2003 | 07:13 AM
stephenlc's Avatar
You can go to a hardware store and make and cut one to lenght for 5 dollars. It just won't be stiff like those hoses.
Old Oct 27, 2003 | 07:30 AM
WizzaMax's Avatar
you cannot just cut it from bulk hose cause without the preshape...it will bind...you dont think we may have tried that already?...Frank if you find a good price...lemme know...I want to get a new one...
Old Oct 28, 2003 | 05:06 PM
jdmmax's Avatar
nissan part number is
11823-31U00
Old Oct 28, 2005 | 12:42 PM
ewuzh's Avatar
Back from the dead!
Can anyone confirm that the SC return hose is the same as the nissan crankcase vent hose? I think mine is leaking.
Old Oct 28, 2005 | 01:18 PM
BlackCat's Avatar
RIP '98 Maxima SE
Originally Posted by ewuzh
Back from the dead!
Yep. My hose had recently cracked and a new part was ridiculously priced at the stealership. I looked through my left-over parts box from the SC install and used that hose. It works perfectly!
Old thread:
http://forums.maxima.org/showthread....oto=nextnewest
Old Nov 11, 2005 | 10:42 PM
ewuzh's Avatar
Old thread:
Sorry to bring this back up, but I just wanted to post my experience with this.
I just tried using this today and it did not fit well. The inner hose diameter is too large and too loose when hooked up. I ended up using a nissan power steering hose (like the ones removed to do the power steering lines relocation). It's a tight fit, but I'd rather have a tight fit than for it to slowly drip oil.
Old Nov 12, 2005 | 01:07 PM
jdmmax's Avatar
well if your using a old crank case breather hose they do thend to stretch a bit and the heat makes the hoses harden thats probably why it did not fit. I used that hose and had absolutly no problems.
blackcat you are telling me that you are willing to spend $2000 + on supercharging you maximas but you are to cheap to spend $20 on an oil return hose????? are you kidding me!?!??!?!
Old Nov 12, 2005 | 07:55 PM
matty's Avatar
I bought a NEW one from nissan when I first installed my blower and it needed to be cut a bit. I put it "as is" and it was crimping it was too long. I but a bit off at a time till it was perfect
-matt
Old Nov 12, 2005 | 09:27 PM
ewuzh's Avatar
Ohh okay maybe that's why. I was trying to use my old/original crankcase breather hose. Now that you mention it, the hose did feel really stiff to the touch.
Old Nov 14, 2005 | 08:25 AM
BlackCat's Avatar
RIP '98 Maxima SE
jdmmax, I have no idea why you even had to comment on this when the problem has been resolved back in June.
Cotozic
Jun 28, 2017 08:01 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
tnewbs
Aug 28, 2015 10:15 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
