CJWT ECU and trading out.
Person A has a SC but no aftermarket ECU - MAF on the charged side (Engine side of the SC) <----the usual setup.
Person B has a Programmed JWT ECU with a MAF on the non-charged side (On the Filter side of the SC)
Person A Buys Person B's ECU - will he need to put his MAF on the non-charged side to make the JWT work properly?
(I'm pretty sure I know the answer - but may as well ask to be sure).
Thanks!
IanS
Thanks!
IanS
Thanks!
IanS
Thanks!
IanS
Aw crud - I screwed up the suject line - any moderators wanna fix that?
Really?
JWT doesn't change the programming depending on where the stock MAF is?
Thought they would - alot more airflow to compute on the charged side.
Anyway - someone is checking some things out for me - I don't know at this point whether it's a Z32 MAF or a stock MAF we're talking about.
Really?
The physics of it just don't make alot of sense to me I guess. I would expect there to be alot more airflow on the charged side, which would then screw up the readings.....if the ECU is programmed to read from the non-charged side.
But then again - it has to suck in as much air as it puts out, I suppose.
So - you guys are sure, right?
IanS
IanS
Its true the maf would read the same air flow on the charged or non charged side. However the MAF doesn't like turbulence, it causes inconsistant readings and erratic running. That is why its put on the non charge side, all FI nissans are like this. The ecu you have should have a label that tells you what injectors/maf that its programmed for.
IanS
IanS
06-06-2017 02:01 PM
