HELP! I want to build a engine that can hold 15PSI, where do I start???
Old Nov 13, 2003 | 12:56 AM
  #41
turbo97SE's Avatar
Sup dude! Ah, I see you now have the parts ... cool! ECU programmed by JWT is probably a good start if you want to piggyback something on top of it. For the kind of boost and power you're looking at, you'll probably want to run 550cc injectors at least. I am not knocking JWT, but it is hard to get accurate maps to optimize power from a standard ECU. If you hold on for a little while longer, there will be something more interesting coming out
For ARP studs, yes call ARP. They have them for our engines now I believe.
As for my other project, that's a secret
Originally Posted by desertmaxima
Hey stranger wassup. What new car are you toying with now. And I have on alerts parts now, well not now seeing that im still in iraq. But that is the plan once I get home is to build the motor up for 20psi plus. I had an old Sport compact out here that was talking about their project 300Z that was running a ECU programed by jwt to run on either pump gas or race gas. Sounded pretty cool to me. Hey Nigel for the arp studs would I just call them up and have em do some custom studs for me or do the 350Z head studs and main bolt work for the VQ30 engine. Oh and ill be calling upon ya at a later time for that turbo kit, just not as soon as I thought with me buying this new motor and internals
Old Nov 13, 2003 | 02:52 AM
  #42
desertmaxima's Avatar
Yea nigel my plan was to use a e manage with the J&S safeguard. Kinda going off the stuff that sx7r has done with his. Im just glad he has shared his accomplishments with everyone here. And what do you mean something more interesting coming out eh. Oh do please tell. Did you get the guys at PFI to do some off the wall stand alone or something. Come on man dont tease like that. Yea ill be calling ARP up once I get home. I know they got the bolts for the VQ35 already. Well keep me posted on what ya got up yer sleeve Nigel
Old Nov 13, 2003 | 05:07 AM
  #43
luckee2bhere's Avatar
Originally Posted by JAY25
I am also getting a 2k tranny to install. It is slightly different size wise. Internals may be different.
Old Nov 13, 2003 | 08:17 AM
  #44
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
104+ is great stuff, but if you want VERY similar results 100% of the time incase you need it, go with an Aquamist Water Injection setup running alcohol/water, around $420 shipped on eBay.
You can easily push 4+psi more without detonation vs. pump gas.
Pretty cool IMO and can't be beat in bang/$ ratio.
Originally Posted by bags533
And daily driving is the GOAL.
That is why I was think 10 PSI on pump gas and maybe 16 or so on 104+.. ofr those APU supra/VENOM viper/100 shot z06 moments
Old Nov 13, 2003 | 11:08 AM
  #45
Quicksilver's Avatar
OT n00bs FTMFCSL
I would run alcohol rather than a mix, but that's just my personal opinion. Alcohol is pretty darn inexpensive, but water is basically free. I guess they both have their good points...
Old Nov 13, 2003 | 11:21 AM
  #46
IceY2K1's Avatar
Water has it's high specific heat cooling advantages, but mainly just to prevent the alcohol from corroding everything. Up to 50/50 seems to work fine at preventing detonation, yet not chewing up stuff.
I think Kev runs 70/30(water/isopropyl).
Old Nov 13, 2003 | 11:25 AM
  #47
IceY2K1's Avatar
Just to clarify what I meant now that I look at it again, alcohol/water injection will give you similar results as 104+ octane as far as deterring detonation, but DEFINITELY WI has a slight loss in power over running 104+.
Common sense though. Just didn't want to sound like 104+ was worthless or anything.
Old Nov 14, 2003 | 07:51 PM
  #48
OT n00bs FTMFCSL
I wonder what hydrogen peroxide would do if injected into an engine...
Probably blow it up...
Old Nov 14, 2003 | 09:32 PM
  #49
Bags's Avatar
VG Ridah's Biatch Hoe
Oh, ok.. I spent ~2 hrs on AW website. GOOD info.. and I am thinking abot it for daily use.. or I should say more than 104 octane.
Setting it up to fire @ like 4000 RPM...
now that I am thinking about it.. would there be any benefit to run both?
Old Nov 14, 2003 | 09:38 PM
  #50
Bags's Avatar
Well would you mind sending me an email about the "something more interesting coming out" ?
And I was thinking the JWT/J&S should work well with each other.
But the thought about the tuning of emanage makes my head hurt.
And YGM
Old Nov 14, 2003 | 09:42 PM
  #51
Bags's Avatar
Can you come by sunday about 1pm or so ?
Old Nov 15, 2003 | 01:50 PM
  #52
OT n00bs FTMFCSL
Where are you going to be? Your friend's place again?
Old Nov 15, 2003 | 02:36 PM
  #53
Bags's Avatar
YES SIR.. call me on my cell phone if you need better directions ..thanks justin
Old Nov 16, 2003 | 12:39 PM
  #54
Mad-MAX_SE's Avatar
Still kickin'
What site did you go to??
Old Nov 19, 2003 | 02:55 PM
  #55
crewchief264's Avatar
your Motor
I am recently boosted as well and have already thought of exactly what your talking about. I haven'y gotten into it really deep yet but here are some options that I know will work. you can figure out exactly how much your gonna grind the crank and bore over if it is needed and have a JE or Arias build you pistons for that application, forged or whatecer at like 150 or so a pop, then you can got to crower and have them make you the correct rods based on your crank demensions and what type of stroke you want, you can even specify as far pistons go wether they are dished domed, where the rod pin is and so on. I was kinda thinking for a temp fix just raising the head with a thicker head gasket, to run more boost. Any ways my point is this is really expensive and should not be left up to someone that doesn't have the correct technical data and know what they are doing. I've put a few postings on here asking the same question and no one here seems to be able to help, so I guess nobody knows the exact details to do the type of mod you and I are talking about-- imean in precise detail with all the correct milling, grind downs, over bores, piston size, finished compression ratio, and part numbers thats what I 'd like, mostly because it takes a lot of time to research and complete something like this and have it done correctly as far as drivablity goes.
Old Nov 19, 2003 | 03:45 PM
  #56
JAY25's Avatar
After examining bags533 motor, seems like our pistons are not that thick at all. Id be pretty happy w/just pistons/rods/headstuds and a new headgasket. I also bought some tools to rip the block apart. Lets see how hard this really is. If not it dont hurt to have a shop to put the stuff in there and I just completely assemble it.
conansriver
Sep 3, 2015 06:38 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
