Question about bolts on the flywheel.. do you need all of them?? :wall:
Old Nov 25, 2003 | 03:42 PM
  #41
Jeff92se's Avatar
I'm needing a caw
He most likely put the bolt on the airgun socket and tried to start it in there NASCAR pitstop style. He should have hand threaded it most of the way and then just used the gun to get it up to the approx specs. Then verify with a torque wrench.
  #42
ejj's Avatar
ejj
Originally Posted by Quicksilver
It wasn't tightened to 95 ft/lbs...dunno where that info came from. It could have been tightened to 195 ft/lbs for all we know (since it wasn't a TQ wrench that was used)...
Gottcha.
Exactly why I don't use impact/air tools to tighten stuff...too much potential for damage.
Old Nov 25, 2003 | 03:43 PM
  #43
Jeff92se's Avatar
I'm needing a caw
Want me to list your real alias?
Originally Posted by hlh0501
Jeff92se
Quicksilver
we have two geniuses on our hands
Old Nov 25, 2003 | 03:44 PM
  #44
hlh0501's Avatar
It's Jeff's fault! I was asking if it was you...(and poking a little fun at the same time )
oh right of course, not your fault...
how are those clear corners holding up for you, proving reliable?
Old Nov 25, 2003 | 03:57 PM
  #45
Quicksilver's Avatar
OT n00bs FTMFCSL
Did I piss in your cornflakes, or are you only screwing around? Sometimes you're hard to read...
I seriously meant nothing bad by thinking you were on_alert or whatever...
Old Nov 25, 2003 | 04:07 PM
  #46
JAY25's Avatar
hmm hmm hmm hmmm
Old Nov 25, 2003 | 04:21 PM
  #47
hlh0501's Avatar
Thanks for the PM, sorry this got so mixed up. It's all good
truly sorry this thread went to hell compliments of Jeff92se. hope all works out on the fly bolts, sounds like you have it under control.
  #48
OT n00bs FTMFCSL
Originally Posted by JAY25
hmm hmm hmm hmmm
Nothing to see here folks...move along
Old Nov 25, 2003 | 04:22 PM
  #49
Jeff92se's Avatar
I'm needing a caw
Hi Hal
Old Nov 25, 2003 | 04:58 PM
  #50
Bags's Avatar
VG Ridah's Biatch Hoe
You don't read so good do you?????
you missed my post where I said the bolts were started by HAND
justin.. I'll get ahold of you tomorrow... and if the helicoil WON'T work... I was thinking the next size up bolt and forcing it into the hole???
Or MAYBE tapping the FORGED CRANK won't be as bad as I think...
This sucks goat nut$
Old Nov 25, 2003 | 05:01 PM
  #51
Jeff92se's Avatar
I'm needing a caw
I be writn/reedin' goodly thank you! I saw the post just now. Must have been stripped before. Did it hand screw the same as the others? ie.. same effort?
Old Nov 25, 2003 | 05:58 PM
  #52
Bags's Avatar
I "think" ... honestly I do not know....
but I tightened all of them with a ratchet and then with the air gun.
I may have done it. Sometimes I think "goodntight" or "the tighter the better" sometimes.
I never thought about checking it before hand.
Although after this I will.
Lesson #212 in doing a motor swap..lol
It just really sucks. I have less than 2 days work remaining and this happened.
My car WOULD be running, if the motor works, by sunday at the latest. Now I have to go into work like a dog mode to try and get it done.
But I have thursday and friday and sunday so I may make it.
Again thanks fo rhte helicoil suggestion
Old Nov 25, 2003 | 07:35 PM
  #53
on_alert's Avatar
Thanks for your useless post
I was just wondering why you said he wouldnt have gotten 95 ft-lbs of torque unless he used a torque wrench? I can definitely put 100 ft-lbs of torque on a 3/8 rachet if i wanted to. And why would a torque wrench give more torque than a rachet?
(sorry to get off track again)
Old Nov 25, 2003 | 07:46 PM
  #54
OT n00bs FTMFCSL
Dude...just forget it. I'm not in the mood to explain the whole thing...just re-read his posts. And the 3/8" ratchets that were there when I was there would not yield 95 ft/lbs TQ because they have a short handle (fulcrum, leverage)...
Right...
Old Nov 26, 2003 | 08:24 AM
  #55
|Bijan|'s Avatar
UCF Lexus
Have yall noticed how bags double spaces in all of his posts?
Old Nov 26, 2003 | 07:02 PM
  #56
OT n00bs FTMFCSL
It's supposed to be easier to read the posts that way...
Old Nov 27, 2003 | 07:35 PM
  #57
Bags's Avatar
got the tranny off and looked at the threads...
about 1/4 inch of the begining of the threads is gone.. it's smooth..
BUT from what I can tel the rest of the threads are good..
Only about 3/4 threads stick into the crank leaving almost a 1/2 inch of hole.
I was thinking of putting longer bolts in ALL 8 holes ..
what do yall think?????
Old Nov 27, 2003 | 09:27 PM
  #58
OT n00bs FTMFCSL
1/4" of the beginning of just the stripped one is smooth, or all 8 for the first 1/4" are smooth?
I wonder why they didn't use longer bolts to begin with.
Longer bolts will work fine as long as there is no kind of obstruction at all...
Old Nov 27, 2003 | 09:58 PM
  #59
Bags's Avatar
sorry justin, Just the 1 hole has 1/4 of the begining stripped.
That's what I thought as well.
Being that I want to keep a balanced load, changing 1 would make it unbalanced.
So I'll get 8 new bolts tomorrow... IF I am lucky the car will be almost done tomorrow.
Call me whenever your coming by. I plan on being there early and satying late...
no rest for the wicked
Old Nov 28, 2003 | 12:33 AM
  #60
MrGone's Avatar
Bag's - again, good luck with it. Just blame it on Bijan, I'm sure he wont mind
Hal, believe it or not, Quick and Jeff really are geniuses
Old Nov 28, 2003 | 05:36 PM
  #61
OT n00bs FTMFCSL
I'm not sure if that was a rip at Hal, or Jeff and I...
lowpost99
Oct 26, 2025 06:53 PM
ef9
Sep 29, 2015 11:29 PM
bumpypickle
Sep 19, 2015 01:07 AM
dcam0326
Sep 18, 2015 04:52 PM
jcvgn
Sep 13, 2015 11:42 AM
