FYI - stock belt is too long for SC tensioner pulley
Old Jan 5, 2004 | 08:23 AM
[maxi-overdose]'s Avatar
as titled. I tried to put the stock belt on while keeping the smaller tensioner pulley. It turned out that I have to use stock pulley instead because the one from Stillen kit/DanNY is too small. Just want to let you guys know in case someone's trying to go back to NA temporarily...either use stock pulley or use a shorter belt by an inch or 2.
Old Jan 5, 2004 | 08:26 AM
ejj's Avatar
ejj
I drove the car for 2 weeks with the stock belt and smaller tensioner pully...one little squeak here and there, but no problems at all.
Old Jan 5, 2004 | 11:12 AM
it still fits...but it is loose and I can bend it more than 90 degree. I turned the adjusting bolt all the way down too....
Old Jan 5, 2004 | 11:21 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
mine's fine and ive had it running for over 2 wks
Old Jan 5, 2004 | 09:41 PM
interesting - what kinda tensioner pulley are you guys using? the one from stillen or ASP? mine's from DanNY.
Old Jan 6, 2004 | 05:42 AM
ejj's Avatar
ejj
I've got the ASP one. I assume they're the same size though.
Old Jan 12, 2004 | 12:14 PM
alright...I think I found out why.
1.I am still using Stillen's pulley bracket.
2.the alternator is still attached to the SC mounting plate.
Old Jan 12, 2004 | 12:20 PM
ejj's Avatar
ejj
Same here when I had the stock belt on.
Maybe its a 4g vs 5g thing?
Old Jan 12, 2004 | 03:17 PM
hmmm....but Jay25 said that we use the same bracket.
can be the alternator/AC compressor have diff. part no.~
Old Jan 14, 2004 | 05:37 AM
JAY25's Avatar
The bracket mounts right up to the VQ. When I bought my 5th gen SCer the old guy was using the plastic pulley as his tensioner pulley until I gave him back the spare stock one.
Old Jan 15, 2004 | 05:37 PM
20thdriven's Avatar
Just took my V2 off last night on my AE.
I'm sure you fixed the problem but maxi-overdose is right... the stock max belt on my 5th gen was squeeking like crazy fully tightened. I bought a 42" and 41.5"
The 42 was a b**** to get on but was a perfect fit.
I ran the "oil in" right to the "oil return," disconnected and plugged the recirc valve and all is perfect.
"must be a 5th gen thing"
Old Jan 15, 2004 | 11:31 PM
I guess it's a 5th gen vs 4th gen thingy then. thx for the confirmation.
why are you taking off the SC?
Old Jan 16, 2004 | 02:45 PM
20thdriven's Avatar
I'll be making numerous trips between chicago and New york, and don't want to worry about belts or sensors going out on the road during the winter. I miss it already
Old Jan 16, 2004 | 03:35 PM
thx
I miss my sc too
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maximan190
Dec 16, 2015 06:01 AM
markevans999
Oct 25, 2015 08:27 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
