5psi never felt so good
Old Feb 22, 2004 | 06:33 AM
  #41
stephenlc's Avatar
Oh, hehe, are you going to see how far you can go on a stock motor then put itnernals in?
Old Feb 22, 2004 | 06:42 AM
  #42
MardiGrasMax's Avatar
Well, I know how far I can go on the stock motor, 450-500whp.
Old Feb 22, 2004 | 09:44 AM
  #43
Well, nope, just shift like a granny!
Old Feb 22, 2004 | 09:59 AM
  #44
Redmax's Avatar
Redlinemax Owner
are u dynoieng soon?
Old Feb 22, 2004 | 10:16 AM
  #45
Maybe, cant deside, I need to get the MAF voltage info from JWT or figure out how to monitor actual injector duty cycle, so I can be sure I dont run out of fuel. I'm at 10.8psi and I think I can push to perhaps 13-14psi. I need to teach the E01 the max boost setting I want to run before I take it to the dyno, but I dont want to push it up that high till I fugure out the fuel situation.
Old Feb 22, 2004 | 10:44 AM
  #46
BigDogJonx's Avatar
Matt I heard you have an eManage but maybe not installed yet. If you get around putting just the injector harness on, then you can monitor the IDC live and datalog it. Its fairly easy to install, just tap each one of the injector wires. No need to cut.
Dixit
Old Feb 22, 2004 | 11:06 AM
  #47
stephenlc's Avatar
I think he just has the E01, not the e-manage.
Old Feb 22, 2004 | 11:45 AM
  #48
BigDogJonx's Avatar
He has an eManage, just not hooked up I believe.
Dixit
Old Feb 22, 2004 | 12:12 PM
  #49
Hey Dixit,
I dont have one yet, but it seems like it may be needed to monitor inj duty cycle. I dont want to risk damaging my E01.
I read your posts on the e-manage group, you all over the injector thing!
Old Feb 22, 2004 | 01:37 PM
  #50
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
why not use this...only ~$60
http://www.impconcepts.com/fuelinjec...torforsale.htm
Originally Posted by MardiGrasMax
Hey Dixit,
Old Feb 22, 2004 | 02:33 PM
  #51
I have the DIY parts fot that, LOL. If the E01 dosnt do it I will just get the e-manage.
Old Feb 22, 2004 | 02:50 PM
  #52
BigDogJonx's Avatar
Hey Dixit,
Yeap. Still trying to figure it out. Got a hold of a scope and will be using that to figure out whats going wrong with the eManage ignition harness.
Soon I will figure this out, but for now the J&S is going to be installed. Matt I gotta ask you some questions about that. Im going to email or PM you on it.
Dixit
Old Feb 22, 2004 | 03:21 PM
  #53
JAY25's Avatar
Wait til you run someone next to you! Youll see how fast you pull away
Old Feb 22, 2004 | 03:39 PM
  #54
DA-MAX's Avatar
actually using the Emanage to log will quite adventageous....you can log and compare duty cyle, RPM, MAF voltage, TPS and boost pressure in real time and log it...so yeah its not a bad idea at all
Old Feb 22, 2004 | 04:25 PM
  #55
I just ordered the E01, ign&inj harnes's and the bost sensor sharing cable. WHOOOHAAAA
Old Feb 22, 2004 | 05:02 PM
  #56
Tatanko's Avatar
Bacon Lover
nice
Old Feb 22, 2004 | 09:18 PM
  #57
Bags's Avatar
VG Ridah's Biatch Hoe
SO your only going with the E01 for boost control and data logging?
Old Feb 23, 2004 | 03:59 AM
  #58
sorry, i have the E01 and ordered the Emanage+++
Old Feb 23, 2004 | 06:42 AM
  #59
Bags's Avatar
ah..ok..
another question matt, sorry for so many, from my understanding you can't run the J&S and the Emanage at the same time.
So are you gonna sit the J&S on the shelf?
Old Feb 23, 2004 | 06:44 AM
  #60
BigDogJonx's Avatar
Kirk, Im going to install the J&S, you can run it with the eManage, all you have to do is just not wire up the eManage ignition harness.
Sort of like when I disconnected it when it was smoking in the car, remember?
Dixit
Old Feb 23, 2004 | 07:24 AM
  #61
Bags's Avatar
Dixit
ahh I see said the blind man.. thanks dixit
Old Feb 23, 2004 | 08:08 AM
  #62
Their should be a way to get them both to work together. I'll wait for the Greddy Z ignition harness or I hope Dixit can get it to work. Once it actually works on our ignition systems, having the J&S in line to just do knock retard should be no problem at all. I hope!
Old Feb 23, 2004 | 08:36 AM
  #63
Redmax's Avatar
Redlinemax Owner
Mardigras it seems to be working fine on my car except that i trip code 0201 at startup , I will be trying to diagnose that a little more within the next couple of days.
Old Feb 23, 2004 | 08:37 AM
  #64
Bags's Avatar
good deal .. thank you
Old Feb 23, 2004 | 09:16 AM
  #65
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Correct me if I'm wrong, but Mardi is still running his VQ30 engine...ie hasn't dropped in the VQ35 short block, correct?
Seems like that to me, but others are asking questions like he has already swapped. I'm pretty sure he said he was going to work all the bugs out of his turbo setup BEFORE he swapped bottom ends.
Old Feb 23, 2004 | 09:19 AM
  #66
IceY2K1's Avatar
VQ35 rods are slightly heavier, yet stronger. They are made out of Vanadium steel, which from what I can find is considerably stronger then typical cast rod material.
Which connecting rods are stronger, the 3.5 liter or the 3.0 liter?
Old Feb 23, 2004 | 09:41 AM
  #67
Vandium, no ****, oh well i guess the Pauter rods will be ok too
Old Feb 23, 2004 | 09:59 AM
  #68
IceY2K1's Avatar
They're handling 450whp in TT 350z, but you'll need more then that.
VQ30, correct?!?
Old Feb 23, 2004 | 10:48 AM
  #69
Bags's Avatar
Damn you and your Vanadium in your 5th gen
4th gen POWHA!!!!!!
Old Feb 23, 2004 | 10:54 AM
  #70
DA-MAX's Avatar
Vanadium sounds like a medicine to treat STDs
rub some Vanadium on that and call me in the morning
Old Feb 23, 2004 | 11:07 AM
  #71
Quicksilver's Avatar
OT n00bs FTMFCSL
4th gen POWHA!!!!!!
I'll give you the stock con-rods out of my VQ35 when I do my turbo buildup (since I already have the Pauter). Dunno if you could use them or not, but what the hell...they look good sitting around
Old Feb 23, 2004 | 12:07 PM
  #72
IceY2K1's Avatar
He'll need the crank too.
Old Feb 23, 2004 | 12:13 PM
  #73
IceY2K1's Avatar
VQ30DE = cold coined cast steel rods
VQ35DE = hot coined vanadium steel rods
Me = same as jOo.
4th gen POWHA!!!!!!
Old Feb 23, 2004 | 01:31 PM
  #74
Redmax's Avatar
Redlinemax Owner
what are the det pistons made of?
Old Feb 23, 2004 | 04:53 PM
  #75
stephenlc's Avatar
Probally same as 4th gen.
You can probally mill to fit the rods on the VQ30 crank?
Old Feb 23, 2004 | 05:13 PM
  #76
AllGo's Avatar
The new Tein H tech springs are made from Vanadium and They,"Technical Innovation", claim that its a Lighter material which give better/softer feeling. I would think unless its some type of forged Vanadium that it wouldn't make much sense for a con rod as it seems more elastic rather than rigid. At least it would seem that way from the verbage in thier advertisements.
Old Feb 24, 2004 | 07:42 AM
  #77
IceY2K1's Avatar
Just swap the rods and crank...
If you buy the VQ35 rods, you've probably had to buy the whole short block, so throw in both.
Old Feb 24, 2004 | 07:46 AM
  #78
IceY2K1's Avatar
Per SAE tech doc on the Second Generation VQ35:
CONNECTING RODS – Connecting rods are usually cold coined to correct the deformation induced in the Isection by the heat treatment process. However, the VQ35DE connecting rods are made of vanadium steel, making the heat treatment process unnecessary. Isection deformation is corrected by hot coining to prevent deterioration of fatigue strength due to residual stress and deterioration of buckling strength due to dislocations. This improvement of I-section strength allows the sectional area of the connecting rod to be reduced for a weight saving.
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
maxfever1987
Sep 6, 2015 06:20 PM
