Walbro Fuel Pump Part Numbers?
Old Apr 30, 2004 | 12:46 PM
Ramius83
I am trying to buy a Walbro Fuel Pump for a buddy of mine, but I cannot remember the part numbers for it.
I know that it is a Walbro GSS342, but what is the FPD*** or something like that? I thought that our fuel pump for the 4th Gen is for the same one as the Talon or Eclipse or something like that, but I forget. Anyone remember?
Also, anyone know the cheapest place? Thanks all.
Old Apr 30, 2004 | 01:19 PM
Jime's Avatar
I got mine here. FPD006 for the 2nd Gen DSM's for the 255 High Presssure.
http://www.autoperformanceengineering.com/
Old Jul 8, 2004 | 07:31 AM
DonSupreme's Avatar
Would I need the High pressure 255 for running 9 PSI?
What would constitute getting the high pressure model?
Old Jul 8, 2004 | 07:49 AM
Chunger's Avatar
My other car is a Hybrid
If you are using the Vortech FMU (bumps FP as boost goes up) then you will want to use the HP version... FP can reach up to 100psi at high boost.
Old Jul 8, 2004 | 08:02 AM
DonSupreme's Avatar
OK that answers that question.
Second how can I visually inspect my FMU disc to check if its the 8:1 or 6:1?
Will I need an adjustable FPR? Or does the FMU already take care of this?
Old Jul 8, 2004 | 09:28 AM
Chunger's Avatar
You would have to measure the disc inside the FMU (I don't know the specs).
The base FP will increase to about 42psi... you would need a separate "adjustable FPR" as THAT vortech FMU does not control it... I believe the the Super FMU from Vortech does, IIRC.
Old Jul 8, 2004 | 10:08 AM
DonSupreme's Avatar
SUPER FMU hmmmm…. Sounds like that maybe easier to install than a separate adjustable FPR.
What are the consequences of the raised base pressure? Will the car idler higher/burn more gas....?
MAXSE5SPD
Sep 17, 2022 04:00 AM
cruce91
Sep 20, 2015 10:23 AM
00MAXI
Sep 2, 2015 10:23 AM
A32goldylocks
Sep 2, 2015 06:39 AM
homewrecker
Aug 24, 2015 08:56 PM
