Professional Clutch Help !?!?
Old May 4, 2004 | 09:39 PM
matty's Avatar
I posted this here and in the 4th gen forum cause I know there are alot of guys on this board that know alot
Alright Ive had this set up for about 1000 miles
-Exedy Stage One Organic Clutch
-Fidanza Flywheel
-11K mile old 01' 5spd Tranny
Now I noticed after the breakin period of roufly 500 miles, I feel the engine in the clutch pedal that I never felt before..I figured it would go away after break in but it hasnt
It only really happens in the upper RPM's (past 4000RPM's when I go to shift only) and you can actually feel it in the clutch pedal...now the guy that did the Job is a very nice guy and never gives up if there is a problem...I really want to try and understand the problem before I go calling him up...I want to call him and know something in a way
What do you think ??
Its almost like a binding, but you can feel the engine in the clutch pedal
This also could be normal and im feeling it now cause its right and before it was wrong....very puzzled
Old May 4, 2004 | 11:10 PM
meccanoble's Avatar
Sports Button FTW
dam matty, didnt know about this problem. Next time i see you i'll let u see if u feel the same on my car. I have the same clutch.
Old May 12, 2004 | 07:54 PM
matty's Avatar
What does everyones clutch pedal feel like on the way down at high RPM's ???
-matt
Old May 12, 2004 | 09:05 PM
Shadow1198's Avatar
Large Member
It could be your engine or tranny mounts. Either ones damaged or worn out can cause excessive vibration since the engine/tranny will be moving more upon acceleration/decelleration. For example, I got a lot of vibration and shaking in my shifter due to the fact that some of my tranny mounts are pretty much shot.
Old May 13, 2004 | 07:54 AM
matty's Avatar
Its only been there since I did my New Clutch and Tranny....Its only under load past 5K and it feels the same all the way down on the clutch pedal
All mounts are new exept the pass side mount and the two engine mounts are poly
-matt
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
zmcneely13
Sep 26, 2015 02:26 PM
carlosvq30
Sep 26, 2015 09:44 AM
