Routing the Belt...
Old May 5, 2004 | 07:32 PM
matty's Avatar
Routing the Belt...
V1 Blower...V1 Mounting Plate...
I forgot to look at how it came off but I replaced the belt and need to get this one put on right...
Maybe a good explination, drawing or possibly any pictures
Old May 7, 2004 | 05:36 AM
matty's Avatar
bump
12345
Old May 7, 2004 | 09:46 AM
BlackCat's Avatar
RIP '98 Maxima SE
Did you check out ptatohed's pdf file up in the stickies section?
There's a pic on page 63 and 74 of 127 of the pdf file showing the belt route.
Old May 7, 2004 | 11:19 AM
matty's Avatar
Yea I see that but it doesnt show how it goes after the pulley behind the blower
-matt
Old May 7, 2004 | 01:50 PM
Kenneth's Avatar
OG :)
Professional installation.
Old May 7, 2004 | 02:35 PM
matty's Avatar
??? Nah im puttin it in...I need to put the blower back on the plate so I need to know how to PUT THE BELT ON RIGHT (before I attempt to put it on the car)
-matt
Old May 9, 2004 | 09:49 AM
matty's Avatar
I need to put the blower back on the V1 Plate...some help would be great !!
-matt
Old May 9, 2004 | 05:08 PM
BlackCat's Avatar
RIP '98 Maxima SE
Hey Matty
Here's a pic of the V2 mounting plate without the blower:
I know that there are differences between V1 and V2 but the concept should still be the same.
The big round hole at the top is where the pulley will be. See that shaved post in the middle? The belt runs straight down from the pulley past it to the idler pulley which is at the bottom. The belt will go under the idler pulley from left to right. The other belt will go past that tall post below the oblong hole and straight down. Hope that helps.
Old May 10, 2004 | 06:32 PM
Mad-MAX_SE's Avatar
Still kickin'
so you talked you parents into letting you keep th SC?
Old May 10, 2004 | 08:09 PM
matty's Avatar
Almost...I still dont have there 100%
-matt
Old May 11, 2004 | 04:01 AM
delio's Avatar
Mattl,
you should see two flat spots on the posts where the bolts go through. The belt needs to route through there. The rest should be easy. If not... bring it to me.
Old May 11, 2004 | 07:43 AM
BlackCat's Avatar
RIP '98 Maxima SE
Any luck matty?
Old May 11, 2004 | 05:28 PM
matty's Avatar
yea Im waiting for the belt to come in at the Auto Parts store...I understand but its pretty different than the V2 Plate
-matt
Old May 19, 2004 | 09:17 PM
matty's Avatar
Delio,
Bring the belts past the rounds spots of the posts or the flat spots of the post
matt
schmellyfart
Sep 25, 2015 04:47 PM
lowpost99
22
Sep 2, 2015 04:38 PM
spidgeon
Aug 24, 2015 11:14 AM
